1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
93 Dies
Old Nov 30, 2008
samscar's Avatar
samscar is an unknown quantity at this point
93 Dies
Hello all ,I have a question and need some troubleshooting advice.Have a 93 civic ex 1.5/automatic. It will start up and run fine for 4 or 5 minutes and then will just die. No spark situation.After it sits for a hour or so it will start again then same problem. Replaced coil still same problem,There was a broke/burnt wire inside dist. that i soldered still same prob. Any ideas you may have please post....car has 199k mile thanks
Old Nov 30, 2008
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
Re: 93 Dies
check eather the main relay or the ignitor in the distributor. both are weak points and can be problm childs.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Le Ormz
Sep 30, 2015 09:24 AM
Skunkone
Sep 24, 2015 04:38 PM
NROD315
Sep 4, 2015 09:22 PM
