Maximum Section Width (for a stock wheel well)
Old Nov 29, 2008
lamawithonel's Avatar
lamawithonel is an unknown quantity at this point
On an EM2 with OEM 63874 or 71717 15 spoke 15x6" wheels, the recommended tire size is 185/65-15. My question is, just how wide can I go before I start to rub against the wheel-well or other components? The Civic based Acura LE sold with a stock 195/65/15 tire on a 15x6 wheel, so I feel pretty safe at that level. But what about a 205?
Just to clear a few things out of the way:
- Since I'm sizing up the difference in odometer readings plays in my favor on resale.
- Any loss in torque is accecptable
- I have no plans to lower the car or change the suspension or breaks.
Old Nov 29, 2008
manahoonie's Avatar
Re: Maximum Section Width (for a stock wheel well)
just a minor correction... it's an Acura EL...
Old Nov 29, 2008
lxcivic2k1's Avatar
According to Toyo's website, my 215/45/17 are 8.4in wide and 205/65/15 would only be 8.1 according to Yokohama. My tires never rub.
Old Nov 29, 2008
TemjinX2's Avatar
widest i went on my civic without and rubbing was 205/40/17.
I could go 215/45/17 once i dremeled off my rear lip in the rear wheel whell.
Old Nov 29, 2008
katzenjammer84's Avatar
katzenjammer84 is an unknown quantity at this point
1) How low are you?
2) How low do you want to be?
3) How much negative camber are you willing to run?
4) Are you willing to get your fenders rolled?
Old Nov 29, 2008
Thanks. The tires I'm looking at run 8.2" at 205 on a 15x6 rim.
Originally Posted by katzenjammer84
1) How low are you?
I want to LOOK as generic as possible to avoid unwanted attention. No lowering, no wide fenders, no crazy body kit, 15" wheels.
Old Nov 30, 2008
Well if you're staying at stock height, you'll be able to run a rather large range of sectional widths. On a 15x6" wheel however, I would go no larger than 205mm.
Old Dec 23, 2008
Pachanga02's Avatar
Pachanga02 is an unknown quantity at this point
I'm lowered with 205 50 16 never rub. Good luck
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
VNlilMAN
Dec 6, 2001 01:25 AM
CapYoda
Nov 29, 2001 07:37 PM
vtecharry
Nov 28, 2001 07:03 PM
htowncivicEX
Nov 13, 2001 04:30 PM
