Gas pedal not working well
Old Nov 19, 2008
imprezagtr's Avatar
imprezagtr is an unknown quantity at this point
my gas pedal doesn't go back up as fast as it used to be when i release my foot. i just replaced the flywheel and clutch. is there anythign i need to check? maybe spring or something that usually push the pedal back? thanks.
Old Nov 20, 2008
Re: Gas pedal not working well
the cable might need to be lubed.
Old Nov 20, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
flywheel/clutch and your gas pedal are nothing related. if you have a civic ex there are 2 spots for the throttle cable to mount on, maybe you mounted it on the wrong one? or maybe your jsut trippin lol. in addition to that maybe you should tighten up your throttle cable.
Old Dec 11, 2008
jackscivic's Avatar
jackscivic will become famous soon enough
Try cleaning your throttle plate. It probally has residue from normal driving causing it to stick. Its a common issue for honda throttle bodies.
Shakzhussain
May 17, 2015 12:03 PM
anddrrey
May 11, 2015 02:30 PM
Ashley Farr
May 7, 2015 05:01 PM
ORskier
May 3, 2015 12:54 PM
CiViCPrAnInG2k1
Nov 1, 2001 03:47 PM
