Monroe Shocks and Strutts?
I want a softer ride and im at about 115 000KM I was thinking of changing the shocks and struts would that be a good investment?
Would they be better for a softer ride because Im putting on 18" Enkies FN18s. Im tierd of feeling all the bumps and stuff in the road and I saw the display at Canadian Tire and as it shows the Shocks seem to be alot softer than stock.
Just wondering if anyone knows much about them?
Re: Monroe Shocks and Strutts?
18's doesn't make it any better for a softer ride because you have to go a more low pro tire... if you want to lower expect it to be a little rough... i would try going with just blues/s.techs. that set up is pretty soft compared to other springs/struts
Well how much softer is the Monroe setup compared to "blue/ Stech" and can thoes come in adjustable set where i can lower it and raise up higher then normal for the winter time just a 1.5" drop and about a 1.5" high?
Im looking for a softer ride nothing sporty.. That 1.5" drop is at MAX I would probably go down about a 1/2" at most.
I just need some advice on getting a softer setup.
Thanks so far tho ^^ +1
what he means by "blues" are tokico blues, preferably with stock springs, is a better ride than with the stock struts/shocks. but like he said, 18's will not help the situation much. but the blues would be the cheaper route than a coilover setup.
Monroe is Oriellys/Autozone junk........only put that on your beaters..........You're softest ride is gonna be stock suspension & stock wheels............You will never ever get a nice ride outta them
Well, I dont have a problem with how it rides now.. I just know it will get a bit ruffer with the 18s.. So I was trying to find a balance and find out what setup could help equal the situation out.
tokico blues and the s-techs?
So dont change the stock springs there what you keep for the best ride quality? Struts/Shocks are what you can upgrade?
I found this site http://www.prostreetonline.com/s/sus...ico-shocks.asp
which of these better suit my needs? I dont care much for a drop, Im more worried about ride quality I know 18s wont help but I wnat somthing that might just a bit
.. More so i dont want to damage the rims.
.. More so i dont want to damage the rims. Re: Monroe Shocks and Strutts?
dude. im sorry. search a little. you always create useless threads that have been covered a million times before. And you always ask about shitty parts. The magnaflow and enkeis being the exception. dont skimp on your ride. or youll pay mroe in the long run, possibly your life with egay coilovers ridin on a dubs with a autozone special shock while blinding oncoming drivers with your glare-ific HID kit and getting called a ricer for your dual exhaust on a 4cyl civic. Just mix a bunch of tried and true paths for mod-wise.
You Gotta Pay to Play.
Is it not possible to get split 2-1 headers rather than a single 4-2-1 header and get true dual exhaust? I wouldn't call that ricey at all...fake dual exhaust is ****ing gay though.
I know I've found some headers like that for Integras before. Sorry if that's a dumb question, I don't know much about Civics.
Thanks speedricerx I tought Bags would be best but thoes are big bang in the bank.
I gota pay to play... well, ive learned to play with what ever little ive got and do it pretty well but thanks for the heads up.
Oh the HID arent that bad
Maybe in a few years when im 20
and i can afford to spend my lunch money on head lights ill do that :>
and i can afford to spend my lunch money on head lights ill do that :> Banished to the Depths of Rice.
actually, Htech springs are softer than stock springs.they are made out of a material called Vanadium and far exceeds our civic oem springs.
okay so Htech Springs with Bags?
Now when I look for bags what are the negatives to changing to a air bag suspension set that you guys have come across if any? (oh ill research the answer at the same time).
i have them w/ tokico blues and the combo is waaaay rougher than stock suspension...i guess it's not as rough as full coilovers but the ride isn't soft
Bruce2
Sep 27, 2015 08:45 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
