96 civic. No automatic transmission filter?
Old Jan 29, 2008
96beatercivic's Avatar
96beatercivic is an unknown quantity at this point
Why would honda not put any kind of filter (not even a magnet) on these cars? Just seems weird to me that the only way to really service one is to have it back flushed on a machine.
Mine is starting to down shift harshly at stops, and found out the only "screen" is deep in the transmission and I would have to remove the whole transmission to clean it.
Old Mar 20, 2008
TheJGB3's Avatar
TheJGB3 is an unknown quantity at this point
Re: 96 civic. No automatic transmission filter?
Honda trannys are "drain and fill" do not use a back flush machine. And yes there is a magnet - on the end of the drain plug. AND THE MOST IMPORTANT THING TO REMEMBER: USE ONLY HONDA ATF-Z1 OEM FLUID
Old Mar 20, 2008
you can buy the HX civic cvt exterior fluid filter, but its prolly too late for that. do it after you get a new trans put in.
Old Mar 24, 2008
Justinsn95's Avatar
Justinsn95 is an unknown quantity at this point
Originally Posted by TheJGB3
Honda trannys are "drain and fill" do not use a back flush machine. And yes there is a magnet - on the end of the drain plug. AND THE MOST INPORTANT THING TO REMEMBER: USE ONLY HONDA ATF-Z1 OEM FLUID
hmm... i havean appointment at a local transmission service shot to get my fluid changed. now i am wondering if i can trust them to use the right kind. maybe ishould just go to autozone and get the right stuff and take it to them and tell them touse my stuff when they cange it? how do you guys change yours when you get it done? and how often does it need to be changed?
Old Mar 24, 2008
well, only the honda dealer sells the right stuff. i usually change mine in the parking lot, every year or two.
Old Jun 18, 2012
midmocfp's Avatar
midmocfp is an unknown quantity at this point
most Car Quest stores carry it or can order it, but not much cheaper in general - if you want to try and save a buck a liter, give em a call
RIPSAW
Nov 6, 2015 04:36 AM
97-DX-Lover
Jun 14, 2015 06:07 PM
vtecbrah
May 31, 2015 01:24 PM
cruisers10
May 12, 2015 10:46 PM
Flipg123
May 8, 2015 01:15 PM
