1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
compression test help
Old Jan 9, 2008
jcpower's Avatar
jcpower is an unknown quantity at this point
hi i have a 1991 honda civic DX and i trying to do a compression test, one of the thing to do is take one of the wires from the distributor cap and conected to ground, witch one,there is two plug attach to the distributorcap and the 4 wire coming from the spark in to the distributor cap,any info will be apprecited, thank you for your reply.
Old Jan 9, 2008
CivicHatch9one's Avatar
7th gen old timer.
CivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond repute
Re: compression test help
are you trying to do a compression check or a spark check?
because the only time you put the spark plug to a ground is to see if a spark comes out. you just pull it out from the valve cover and put it to a nut or something that is grounded if you hear and see a spark than that one is good...
as for compression
you need a compression meter and you hook it up to the Cly and then get the reading off the guage. you test each one. find out what it should be in the book and then if one of them is low then there is no compression.
good luck
Old Jan 9, 2008
RHCP0801's Avatar
for a compression test you first need the gauge, than take out each spark plug and screw in the tester than crank the engine for about 3 seconds and than note the reading on the gauge
Old Jan 9, 2008
7th gen old timer.
lol didnt i just say that? thanks adam.. you just described it better.
Old Jan 10, 2008
jcpower's Avatar
In the Haynes book described that you need to disable the gas pump by taking the main relay out, also lock the throttle body in a full open position and take the primary cable from the center of the distributor cap and ground it, is this necessary to get an accurate reading
thank you
Old Jan 10, 2008
RHCP0801's Avatar
lol ummm yea of all the compression tests i have done i never did any of that and neither has anyone i watched do it...just do it the way i told you if you would like.
and yes pete i just repeated what you said lmao didnt even realize it
SimpleUser
Apr 24, 2021 02:54 AM
OptimisticWay
46
Oct 15, 2015 02:16 PM
martinsmartin
Aug 15, 2015 07:34 PM
darwin-t
Aug 15, 2015 10:51 AM
fred57
Aug 1, 2015 08:45 AM
