Help please!! 2001 civic ex
Old Oct 17, 2007
shoelouis's Avatar
shoelouis is an unknown quantity at this point
Angry Help please!! 2001 civic ex
My gauges do not work and the illumination of the guages and center consol are out. The only thing on is the emergency brake light but the car works perfectly fine other than that.The car is stock no mods . It was a intermident problem but now its all the time. Any suggestions i need help ! thank u all in advance. 2001 civic ex 2 dr
Old Oct 17, 2007
manahoonie's Avatar
Re: Help please!! 2001 civic ex
go to car dealer
Old Oct 18, 2007
Kevbotron's Avatar
I like my commute
you blew a fuse.. open your fuse box, locate the fuse for interior guage lighting and replace
Old Oct 18, 2007
Nitro Express's Avatar
Nitro Express is an unknown quantity at this point
Doubtful that it's a fuse, being that the problem was intermittent. A fuse is either good or bad. I'd check the fuse then go to the dealer. Sounds like a short somewhere in the system. Good luck.
Old Oct 18, 2007
new cluster from ebay will cost less than paying the dealer to diagnose the problem that you already know
Old Oct 18, 2007
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
if it aint a fuse then its the whole cluster. Anything goes bad in the cluster then you have to replace the entire unit. You should also check the little bulbs on the back of the gauge cluster aswell.
Old Oct 18, 2007
shoelouis's Avatar
one of the bulbs was out and i just replaced it so far so good only time will tell if thats it i will let u all know! Thank u all for the help!
Old Oct 18, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
well if you need a new one i have my old one forsale
Old Oct 18, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
if the fuse blows on anything.......then there is a short!
fix the short, and you fixed the problem!
mattdoc
Mar 14, 2017 12:10 PM
bambuski
Nov 12, 2001 10:35 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
