1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
VX shuts off while driving, lunges horribly on acceleration and tach needle jumps!
Old Sep 22, 2007
nickf829's Avatar
nickf829 is an unknown quantity at this point
Exclamation VX shuts off while driving, lunges horribly on acceleration and tach needle jumps!
I have a 92 honda civic vx, when im accellerating sometimes my tach will drop to zero quickly and the car will lose power but then jump right back up to where i was and it will lunge at that point.. its like the car loses power for just a split second. its really annoying and i don't know what to check
and now my car has completely shut off when slowing down twice. ill be coming down the mountain doing about 25 and it cut off once, where i had to pop the clutch just to get the car to start back up so my brakes would work right, and the other time was coasting into a stop sign, the car just shut off quietly and all the red lights on the dash came on but the radio and everythign stayed on, i tried just turning the ignition over at the stop sign, but the first time i cranked it, it started up but the second i hit the gas, it cut off. so i waited a minute and started it up again and it stayed running and allowed me to keep driving
for the last couple of weeks, before these above things started happening, the tach(its the factory tach) has been going nuts on me.. ill be driving along at about 2000 rpm then all the sudden the needle will start jumping around like a mad man and will eventually settle back into 2000rpm for a while, then start jumping around all over again. i don't know if this has anythign to do with it or if its just maybe the tach is going out.. but i figured i'd throw that out there
anyone have any ideas on wtf is going on?
thanks
nick
Old Dec 3, 2007
Xhondatech's Avatar
Xhondatech is an unknown quantity at this point
Re: VX shuts off while driving, lunges horribly on acceleration and tach needle jumps
well nick.. it could be a possibilty of a couple of things.. if the tach is jumping around there is obviously something wrong.. my 87 crx did that and i had to replace the distributor to replace the crank angle sensor.. that fixed it and fast... but your problem sounds like it could me an ECU problem.. my uncle had a problem with his car... granted it was ford escort.. (BIG PILE THERE).. it would be warming up and be fine.. but as soon as it warmed up then it would do exactly wut u described.. let me know wut u find
Old Dec 10, 2007
sentbacktothesu's Avatar
sentbacktothesu is an unknown quantity at this point
sounds like the distributor. but im no mechanic. my moms 95 dx did that then eventually just died. it always stalled on her.
Old Jan 8, 2008
Unix's Avatar
Unix is an unknown quantity at this point
Sounds like the dizzy coil. Replace the distributor from another D-Series ($30). It's a common problem in the D15Z's.
Xuhme
21
Aug 7, 2023 03:40 PM
jbradley4809
Apr 7, 2017 04:23 AM
Bruce.Ringler
Jun 18, 2015 08:12 AM
lildoo
May 9, 2015 09:44 AM
smmahan
Apr 15, 2015 08:17 PM
