Ground Control (Eibach) CoilOvers
Selling my set, used, fit on 01 EX. I have all springs/sleeves and original directions. You'll need to get new o-rings for them tho. $60 Shipped.
Re: Ground Control (Eibach) CoilOvers
dibs? i was told that all you need is an adaptor or something to make these fit with koni? also why wont it fit the koni? if so i will take these... PM me i got the money.
they arnt wide enough I believe...not sure for sure tho, if you contact the company they are really good. but I think i put under 1k on them, but they were used before me
the ones for konis have a black adapter in the middle for the rears. I don't think you can buy it separately because it has to be glued in.
whats the max drop on these? 2.5? i have a sedan will the spring rates be off horribly? i looked on there website and it didnt specify between the two. where could i get these o-rings and is the adjusting wrench included? thanks
I got a wrench from my friend, ill have to find it again, the orings are shot, I might send two decent ones if I can find them too. The drop is pretty damn low and they are hard springs, I'd say they'd be great in an auto-x setup...
danmit i want these so bad, but does anyone know if the shock/strut assembly changed between 01 to 03?! lol. these wouldve been sold a long time ago but im still trying to find out
You can't use these. They are made for 50mm shocks and you most likely have 55mm shocks.
01-02 have a 50mm housing, as for the 03-05 have the 55mm housing.
if your gc fits perfectly for the 01-02, then it might not fit the 03+ because of the extra 5mm.
but then again, if you are running aftermarket(such as tokico blues, they are made for 01-02 and 03-05 have teh same tube diameter, but i dont know what it is), it might fit.
btw, 01-02 shocks uses 14mm bolts, where as 03+ uses a 16mm bolt.
btw, did u get the inner diameter?
ok i will buy these today..jsut a little more info. sorry if i didnt catch it. i have an 02 coupe..stock struts..will everything fit right? and where do the o rings go..how do i ge those on or what not and how much will they cost me..
??? let me know asap please, ill take em off ur hands.
EM_WON
Jul 22, 2015 06:49 PM
