CV joint covered in oil, boot busted.
Old Aug 17, 2007
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
My front CV joint, when looking inside the outbound boot, looks like it is covered in oil. I don't know if this is normal, but the boot is obviously seperated all the way around, and there is oil all around the wheel area. I need to replace the boot, but I'm not sure how difficult it is. Also, there is a rattle sound in the same area. When I bought the car, the top of the shock, when looking at the engine, was covered in oil, as if the shock burst and came out the top. I imagine the sound is happening because of the shock.
I looked in the shop manual to get an idea, and it seems I need a ball joint remover to get to the boot, or am I wrong? If I'm right, how much does this tool cost? Damn, it's always a can of worms...
Old Aug 17, 2007
Da1lyDr1ver's Avatar
Re: CV joint covered in oil, boot busted.
yes, you will need a ball joint remover. as for the cost, i'm not sure. but, to me, it would seem irrational to buy a ball joint remover, especially if changing a CV joint is a rare occurance. if i were you, i'd check with the local auto supply stores to see if they have one for rent instead.
Old Aug 18, 2007
Thanks. Yeah, kragen or autozone has them.
I ended up taking the split boot and joining it. I cut it around with scissors to remove excess, and then slipped the large hump over the small hump. Poked holes for the nylon tie to go through, then secured it. I used 8 ties. Don't ask, it just works, and I wouldn't recommend it since it's a bitch. I'm broke right now you see...
Old Aug 18, 2007
dru106's Avatar
ThE CoRRupToR
All you need to do on that part is hit the lower control arm with a hammer next to the ball joint and at the same time stick a pry bar in between to give it some pressure
Old Aug 18, 2007
KaotiK TrendZ's Avatar
Performance Parts
KaotiK TrendZ is on a distinguished road
yup, my wifes accord recently had the same thing happen. There was a little vibration because both the inner and outer joints were wearing. It doesnt cost too much to just replace the whole transaxle, which comes with a new boot and joints.
Old Aug 18, 2007
The other boot on the other side is about to go soon. I will replace both boots when the time comes. Do the inner ones ever need to be replaces?
Old Aug 18, 2007
Performance Parts
Our her accord, the boots on the outside split just like that, but i could feel that the cv's were going out. On her accord, there are the outer and inner cv's, which both needed replaced. Runs smooth with no slinging of grease.
Old Aug 18, 2007
Johnold's Avatar
Johnold is an unknown quantity at this point
man that sucks!. Hey, exactly how does a CV joint BOOT go bad like that anyways?. Do any of you guys know how or why they just go bad and break? would the way you drive have anything to do with it?. and would someone benefit from touching them up by jacking the car up and washing them with soap and water then hitting them up with rubber softener/conditioner?
Old Aug 18, 2007
The rubber dries out, then when you work the boot, it starts to crack, eventually splitting. What I would do if you want to prolong their life is, every year put a lite coat of motor oil all around it, which absorbs into the rubber.
Old Aug 18, 2007
dru106's Avatar
ThE CoRRupToR
Inner ones rarely go compared to the outter ones cuz they dont flex as you make turns they stay stationary thats why rwd cars rarely go bad compared to fwd...
IM not sure if theres anyway to prevent it from happening again cuz I just had mines replaced like 2 months ago and now it has a puncture on it throwing grease all over the rim. Most likely I hit something on the frwy.. I would recommend getting an OEM boot kit for better quality which I got replacing it the 2nd time....they are around $30 each and it comes with everything, grease, axle pin, and axle nut.....
Old Aug 18, 2007
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
spray them with silicone spray every once in a while and they wont crack.
Old Aug 19, 2007
Where did you buy your kit?
Old Aug 20, 2007
dru106's Avatar
ThE CoRRupToR
Dealers!!!
Old Aug 22, 2007
Johnold's Avatar
I think that S100 makes a rubber conditioner called "Engine Brightener". It's supposed to be for plastics, rubbers, (some painted metals) and the engine cases for a motorcycle (mainly Harley Davidson). It's pretty cool stuff!.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
Vaguexo
Jun 13, 2015 04:11 AM
toastyghosty
37
Jun 10, 2002 01:07 AM
