Archive - Canada Forsale/Trade eh? Only post here if you have item for sale in Canada and will only sell to someone in Canada. Please start threads with your Province, like this: ON: or AB:
WTB: Ksport hub adapters and Tein spanner wrenches ASAP
Old Jul 15, 2007
jamis33's Avatar
You Stay Classy, San Diego
Ok so i bought a set of tein flex coilovers and im kinda pissed because the hole is 16mm and i have an 01 with 14mm bolts. I can either drill out my hubs to 16mm OR i heard ksport includes adapters with its coilovers that make the holes go from 16mm to 14mm. I would really like to get these asap. As for spanner wrenches. The guy who i bought the coilovers from couldnt find his spanner wrenches so now i need to get a set before i can adjust the height. PLEASE HELP ME OUT HERE!!!!!!!!!
Old Jul 17, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Re: WTB: Ksport hub adapters and Tein spanner wrenches ASAP
Did you buy RSX Tein Flex?
Check this thread out on TCC..
http://www.torontocivics.com/tccforu...hreadid=151568
He's selling them for 20$ (Wrenches)
As for the Adapters, They wont work for you, they are for people that have 16mm Knuckles and want to use 14mm Knuckles. Its basically a sleeve that goes in the hole that decreases the size make the bolt sit flush within the knuckle.
You might have to switch to 03-05 Knuckles for it to work.
Old Jul 17, 2007
mugenman's Avatar
"mmmBAHHHH" - vtec y0
dude go to your local autoparts store and just get some tie rod ends for 04 and up thats what i did with my 03. needed 01-02 tie rod ends for my teins to work.
Old Jul 17, 2007
jamis33's Avatar
ok i have tein flex coilovers for a 2001+ civic and they have the wrong size holes and i was talkin to ksport abut it and they said that they are $2 each and they are the right thing i think. And still couldnt i like get them welded onto some bolts in the right spots or something i dunno. The seem useful tho for $2
Old Jul 17, 2007
mugenman's Avatar
gonna be easier to just get the new tie rod ends. that way theres no welding involved
Old Jul 18, 2007
jamis33's Avatar
its not a problem with the tie rod ends. Its a problem with the hubs. my steering hub bolts are 14mm and he steering hub holes on my coilovers are 16mm. Tie rods have nothing to do with it.
Old Jul 18, 2007
Nameless's Avatar
TURTLEonK
You are saying you have an 2003? and you got 2004 Tie Rod Ends? They are the exact same.
What he is talking about has nothing to do with Tie Rod Ends.
His Crash Bolts or Knuckle Bolts are 14mm because he has an 01-02 Civic,
03-05 have 16mm bolts which means he either needs to switch his knuckle assembly to an 03-05 version for his Flex to work.
The KSport Adapters will not work for you... If you want these coilovers to workwithout having to switch the knuckle assembly, you'll have to take the fronts to a shop and have them rig something up that will reduce the size of the hole.. either by welding it and re-drilling the holes or something along those lines.
Good Luck!
Old Jul 18, 2007
jamis33's Avatar
actually im thinkin about makin a DIY if things go the way they look like they're going im going to get a machine shop around where i live to make me some reducer washers. They make them at a local hydraulic store. Im going this afternoon to see about gettin them made. If not i'll get some of those ksport adapter sleeves and cut them up into little sections the width of the 16mm holes then weld up some 14mm washers to them so they just pop in the holes.
How much would 16mm hubs from a junkyard cost?
Old Jul 18, 2007
mugenman's Avatar
actually i have an 03 and i got 01 tie rod ends. and yes i misread his post so sue me
Old Jul 18, 2007
Nameless's Avatar
TURTLEonK
I honestly couldnt tell you, some places may cut you a good deal while others will try and rip you off so its hard to say.
Old Jul 18, 2007
jamis33's Avatar
hey i was thinkin tho could i just get those adapters from ksport and cut it so it just fits in the hole cuz it wouldnt go beyond or behind it cuz of the bolt and he hub is a different size. It seems like it would work. I think im gonna try it.
Old Jul 19, 2007
Nameless's Avatar
TURTLEonK
What will you use to cut it? youve gotta be very precise or you will have some play which is not good at all.
Old Jul 19, 2007
jamis33's Avatar
ive got a pipe cutter. I also have a jig saw and a rotary tool. It really cant be that hard to cut it out. cut it with the rotary tool then just grind it down till its the rite size. I think rite now im gonna try makin some bushings out of random stuff. What do u think i could make them out of. Something fairly strong and easily pliable. I thought about using like rolled aluminum sheet and cutting those and i dunno makin some spacers out of those. That cant be too hard. Wutever im gonna try just like wrapping the bolts with something so they dont oval out the holes. Cuz if wut my shop teacher told me is right if object a hits object b and object a is softer than object b no damage will be done to the surface of object b. but if object b (the harder one) hits object a than damage will result. Thus proving that a simple piece of rubber or even duct tape will stop the holes from ovaling out. CORRECT??????? or am i way off
GolNat
Nov 27, 2018 03:32 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Mc7602
Sep 17, 2015 02:01 PM
Jrosa
Sep 14, 2015 08:24 PM
