HUGE Part out! Turbo, SI, Spoon, HKS, Greddy, KMS, EVERYTHING FOR SALE!
Old Jun 23, 2007
Hwoody77's Avatar
Hwoody77 can only hope to improve
Well the time has come to finally start parting out the Civic. So I have A LOT of parts for sale.
*****PLEASE READ****
I will be updating this thread constantly as the parts come off my car, and as I find parts lieing around the house, so be sure to check this thread often because I still have a lot of other parts for sale.
Also, for a lot of these parts I am going to need the OEM parts in return. But if need be I can ship out my item first and wait for you to ship out your part back so you have no downtime. BUT that will require that you leave a deposit for the part so I know I get the OEM part back. Also please check my feedback on eBay and 7thgencivic, so you know I am not here to screw anybody and you are buying good parts.
Ok, so where do I start.
The first thing I have for sale is a FULL Intercooler system for a EM2 Civic, with FULL piping, clamps, an intercooler, BOV, and BOV Flange.
This is full custom piping, that runs on both sides. The BOV is a Greddy Type S BOV, and I pressure fitted the intercooler to 20 PSI without any leaks.
The piping was a little dirty when I removed it all, but I cleaned it up a little. A lot of the spots are just stubborn oil and dirt stains that can be removed. The BOV is in perfect condition and I ALWAYS got compliments, because it sounded awesome. High pitched and long. The right side of the piping, has a few dents from hitting the frame, and some scratches on the bottom of the piping, but nothing too bad and it dosen't affect functionality at all. It also has a rust spot where the welding was done, but that can be removed with some CLR I believe.
The price for custom piping alone is expensive, plus a BOV, a BOV glange, the intercooler and everything.
Price = $600 plus shipping
Vacuum Manifold with Hose and Connection
Ok this is for a vacuum manifold and hose with all the fittings already install. Basically a plug and play vacuum manifold. I WILL NOT require any OEM parts in return for this. It hooks up right in the back of the intake manifold.
$60 shipped.
Next is a RevoTeknika short shifter, with CapnYoda's bushings. I will let this go for $50 plus shipping, but I need the factory shifter.
I also have a fake Type R Shift **** and a pre cut AUTHENTIC Type R red stitching shift boot for sale...I can combine all three items for $110 shipped.
This picture has the boot down, but I changed it to move the boot up.
That's a picture of it installed.
I have both door panels done in red suede, which I did myself, so they aren't perfect, but they are damn close. They look good with a few marks and scuffles here and there but it still looks good.
$50 plus your factory door panels. I can also install them if you purchase them and are local.
I have factory Civic SI seats with the red stiching. Pretty good condition, they are clean, just a few scratches on the PLASTIC sides from installation, but nothing that you can really notice. $350 plus your factory seats, again I can also install these, but they are an easy install because I have the brackets bent already.
Factory Red stitching Civic SI Steering wheel, this thing is awesome, I hated that big four spoke factory wheel, and you get to keep the airbag.
Has some regular wear and tear but nothing crazy.
$200 plus your factory steering wheel.
Now for another big part, a FULL return full system.
This is what this will include.
The factory full pump assembly, with a Walboro 255 LPH fuel pump. It comes with enough HIGH quality stainless steel hosing to do the full system (I have the whole hose that runs under the car and fittings) , with ALL the fitings. An Aeromotive FPR with a Jeg's Fuel Pressure gauge installed. Also comes with the fuel rail, with the welded on fitting. The hose that goes from the FPR to the rail and RSX Injectors. Everything you need for a returnless fuel system.
This will also include about another 4 RSX Injectors that are missing O-rings and such, but I won't be doing anything with them.
$500 plus shipping, plus OEM Fuel tank assembly, just what is in your fuel tank. I have not removed the pump and assembly from my tank, but when someone purchases I will remove it.
VIS CF Hood
Used, in OK condition. It has a spidercrack from the inside from my wastegate, which moved to the outside, so the only way to fix it is by painting it, or putting a sticker, or runing some new clearcoat.
Cheap because of the crack $100 plus your factory SSM hood.
Parts I currently have on eBay.
FULL Greddy Ultimate E-Manage with Harnesses and extras
Voodoo Manual Boost Controller
Autometer Pro Comp Boost Gauge
Autometer Pro Comp Volts Gauge
FULL OEM Civic Engine Harness
FULL Greddy Ultimate BLUE With harnesses and support tool
Greddy Black Turbo Timer
SRT-4 577 CC Injectors
Push Button Start Panel with Switches and Ignition
Other parts I will have for sale in the near future...
AEM Uego Wideband Gauge
Wheels
Fiberimages CF Lip
Autometer Gauge Pillar pod
Spoon Sports Lower Tie Bar
KMS Intake Manifold
RSX Rear Sway Bar
And other stuff I can't think of right now.
If you are local I welcome you to come check out the parts in first person, thanks!
Old Jun 23, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
Re: HUGE Part out! Turbo, SI, Spoon, HKS, Greddy, KMS, EVERYTHING FOR SALE!
if only you were closer. id take your seats and maybe ur short shifter setup!
free bump
Old Jun 23, 2007
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
your car looks clean....but why is your watsegate sitting so high and u don't have a dump tube =)
Old Jun 23, 2007
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
are you selling the front lip? dibs if you are
Old Jun 23, 2007
Comptech's Avatar
Comptech will become famous soon enough
how much just for the cfhood shipped to 93033? with out a trade if possible.
Old Jun 23, 2007
Hwoody77's Avatar
That's where the manifold put it, no where else to go with A/C.
And I installed a dumptube the next day, that was a few days after I installed the turbo and I was having trouble finding a good dumptube that fit.
Old Jun 23, 2007
Hobo075's Avatar
Hobo075 is an unknown quantity at this point
springs and coilovers? mite be interested.
Old Jun 23, 2007
civic-driver's Avatar
civic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond repute
absolutely love the si interior wish i could justify the purchase of new seats and steering wheel . bump for some good looking stuff
Old Jun 23, 2007
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
free bump, i'd get some stuff from you, but i just splurged on a boost controller and turbo timer from skipbarber
i'll check back in a few weeks and see what you still have, subscribed...
Old Jun 24, 2007
Blackpaladin's Avatar
Blackpaladin is on a distinguished road
PM'd you let me know asap
Old Jun 24, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
damnnn nice stuff. can you PM me details on IC piping minus the bov? was there any mods involved in making the piping fit to the bumper/frame etc? do you have the pnp harness for the emanage and if so how much. thanks..
Old Jun 24, 2007
Hwoody77's Avatar
Well the thing is if I weren't to include the BOV and that flange you would have to get a custom one made of the same purportions. If I remember correctly there were no mods necesary in making the piping fight, I think the only thing I had to do was save the inside of the bumper a little, but nothing major.
I don't have the PnP Harness for the E-Manage, I just wired it up manually.
Old Jun 24, 2007
SSMCivic2k5's Avatar
SSMCivic2k5 has a spectacular aura aboutSSMCivic2k5 has a spectacular aura aboutSSMCivic2k5 has a spectacular aura about
interested in seats, i live in clifton...hit me up
Old Jun 24, 2007
1sykcivic's Avatar
RHCP0801 is my hero
1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute
how much for frontlip
Old Jun 24, 2007
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
dibs on manifold
Old Jun 24, 2007
robbclark1's Avatar
Retired suspension supermod.
dude, you got front camber bolts for me? You know you love me!!
Old Jun 24, 2007
Kevbotron's Avatar
I like my commute
Are those sides available?
Old Jun 25, 2007
Hwoody77's Avatar
The only thing that won't be coming off the car is the sides and rear lip, the front lip is a custom Fiberimages lip, painted SSM on the sides.
That will be for sale in the near future, as will the manifold, wastegate, turbo, ground kit, KMS intake manifold, Megan Full suspension and a few other things...
Old Jun 25, 2007
i need da kms intake asap.. pic and condition. what mods have to be mad in da engin ebay. elem knwo ill be glad 2 buy asap..kukixkronicx408 u can im me also
Old Jun 26, 2007
Kevbotron's Avatar
I like my commute
Okay cool, I'll have PayPal ready for when you are looking to sell the sides.. thanks! (hope I understood that correctly)
Old Jun 26, 2007
we still meetin up?
Old Jun 27, 2007
Hwoody77's Avatar
Originally Posted by SSMCivic2k5
we still meetin up?
Yes sir, I PMed you back.
Old Jun 27, 2007
sooo give me the red suede thign for free since i buyin ur seats!
Old Jun 27, 2007
blouisgod's Avatar
Life Begins > 6800rpms
pmed you on the lower tie bar
Old Jun 27, 2007
how much for the front lip??? dibs
Old Jun 28, 2007
Hwoody77's Avatar
I said that WON'T be coming off the car, sorry dude.
Old Jun 28, 2007
Hwoody77's Avatar
I could cut you a deal, we can discuss when we meet up.
Old Jun 28, 2007
where we gonna meet up then? u know were like clifton commons is? i think thats like mid way since i usually stay in edison area
Old Jun 28, 2007
are selling ur car? or just back to stock? wanna trade mirrors also? my paint is bit off! ahha
Old Jun 28, 2007
Hwoody77's Avatar
I can't really meet halfway because the car is currently parted out, so it's not running .
