2004 Sedan Civic EX Shocks/Strts ok on 2001 Sedan Civic LX?
spell check pwns you
Re: 2004 Sedan Civic EX Shocks/Strts ok on 2001 Sedan Civic LX?
the rears should fit i believe but the front will not. the bolt sizes are different for the camber bolt. 04-5 and some 03 are larger. 01-02 are smaller.
i got 04 rear stock shocks and springs with under 10k. let me know if your interested
01-02 front struts are 14mm where as 03+ are 16mm.
the housing on the front 01-02 are 50mm housing where as 03+ ar 55mm.
thanks i dont have the specifics in front of me. but i do know that some 03 are mixed on teh specs cause honda did the change then.
so do you guys know which 2003 models would have 14 mm bolts? My 03 was manufactured Oct 02 and i had a set of 03-05 tokico hp installed and now i am worried i have a 16 mm hole over a 14 mm bolt....
well 01-02 have the bolts 14mm but the 50mm to 55mm are mixed for the year for honda so they say you have to measure before you purchace in some cases
As long as the upper mount and the shock match up, then it doesn't matter about the 50 or 55mm. That is, the upper mount has to be for a 50mm shock if you use one. Either than that, they can go on any car barring the 14/16 mm bolt problem.
Is this really a huge problem? Would it still be able to be installed regardless since it's a small difference in bolt sizes? I'm assuming a 14mm bolt head wouldn't go through a 16mm or 50mm bolt head going through a 55??
LionSpratt
Jan 29, 2017 11:07 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
