Idol problems
Old Apr 30, 2007
Got Boost?'s Avatar
Got Boost? is an unknown quantity at this point
Exclamation Idol problems
Just want input...
I have a 6th gen of course... 98 civic ex but my problem just recently started about a week or two into march. Im having trouble idoling when I am warmed up sitting at lights and parked (400-500rpms) but if I activate the ac or heater it idols normally (750-800rpms)... idk if this is normal or not thats why I am asking ppl here. There is a twist I have messed with the timing and throttle cable already but it doesnt effect it. I am running 40psi through my AEM fuel rail with the help of the adjustable fuel pressure regulator. The normal psi is 35 so I shouldnt have a problem. My step dad thinks it might be my disturbitor going because of the advancement of the timing... Help plz...
Old May 1, 2007
elusive_da's Avatar
elusive_da is an unknown quantity at this point
Re: Idol problems
first id start the car, warm it up, leave it running, take off the +batt. term, if it dies its ur alt. if not then adjust the idol screw, its a gold colored flat head screw on the throttle body....good luck
Old May 2, 2007
Got Boost?'s Avatar
Smile Re: Idol problems
hmmmm thanks a lot dude
Old May 2, 2007
elusive_da's Avatar
Re: Idol problems
did the problem clear up????
Old May 3, 2007
Got Boost?'s Avatar
Re: Idol problems
Yeah actually it did and in the process I found a vacuum leak in one of the hoses as well. Thanks a lot elusive for the insight!
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
