k20 injectors w/ SF fmu??? does it work?
Old Apr 25, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
alright well im running ex injectors on my boost set up now @ 6 psi. someone told me that i shouldnt use the rsx-s injectors with the fmu because i cant control them. i dont know why but yeah, im pretty sure they are maxxed out. i was wondering if i could pop in the rsx-s injectors without having problems? and... is there anyway to make my vtec work without the oil pressure switch? i got lx everything with ex head. i got the vtec solenoid and everything just no oil pressure switch. i think its that big thing on the water block that looks like a distributor. i have the ex wiring harness and the ex ecu so the plug is just hanging there. any help is appreciated thanks in advanced!
Old Apr 25, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: k20 injectors w/ SF fmu??? does it work?
The big canister thing is the EGR valve. the VTEC solenoid is on the back passenger side corner of the head.
RSX injectors wont work because you have nothing to control them. The stock ECU thinks you have 240cc injectors, it will attempt to run the car as such. you need an emanage or something to correct the flow rate.
Old Apr 25, 2007
thank you sir
Old Apr 25, 2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
you dont need the oil pressure switch to run vtec. i swapped in a a2 with only a vafc2 wired directly to the vtec solenoid still and still running the lx exu. the oil pressure switch will just tell the ex ecu there isnt enough oil pressure to engage vtec if you ran low on oil. just make sure you always have oil and youll be fine not hooking it up.
SimpleUser
Apr 24, 2021 02:54 AM
martinsmartin
Aug 15, 2015 07:34 PM
fred57
Aug 1, 2015 08:45 AM
opto_isolator
Engine Swaps
Oct 8, 2003 07:49 PM
yourinmyw0rld
Aug 5, 2003 02:42 PM
