Parting out my 95 Civic EX
Old Apr 3, 2007
Blinker's Avatar
Blinker is an unknown quantity at this point
I'm looking at parting out the 95 Civic Ex. Anyone interested? PM me. I would like the engine, trans and computer to all go together if possible. Everything will be going on E-bay shortly, so hit me up now before parts start hitting E-bay. The car is complete, so I would have even the smallest, or rarest item your looking for.
This is everything... I think
Head (D16Y8)
Felpro Permatorque Head Gasket
Comp Cams Quick Time Cam (ZEX 59300)
Zex Springs
Zex Titanium Retainers
Oversized Valves
Intake : 30mm (non v-tec integra)
Exhaust : 27mm ( JDM DOHC ZC motor)
Ported & Polished with a 3 angle valve job, street & strip Class from JG Edelbrock.
AEM Tru-time Adjustable Cam Gear
Head milled .040 over.
ARP Head Studs
Polished Valve Cover
Auto to Manual Transmission Swap
Luks clutch
B&M Short Throw Shifter
Engine Block (D16Z6)
Eagle H Beam Rods
JE Pistons 10:5:1 Compression
JE Chrome Piston Rings
High Performance Rod & Crank Bearings
Block has been notched and bored to 2.975
Fully balanced crank, rods, and pistons.
AEM Fuel Filter
B&M Fuel Pressure Regulator
AEM Fulle Pressure Regulator - New in box - Red - Never Installed
B&M Fuel Pressure Gauge
Venom Polished Fuel Rail
Venom High Flow Fuel Pump
Venom High Flow Injectors
Ractive Cold Air Intake
AEM Bypass Filter
Apexi V-AFC
Ractive Fireball Muffler
Ractive Nickel Plated 4-2-1 Header
Ractive High Flow Catalytic Converter
MSD Blaster Coil
MSD Sport Compact Ignition
MSD Distributor Cap
MSD 8.5mm Spark Plug Wires
Venom VCN 1000 Nitrous Unit
Edelbrock Purge Solenoid
Unorthodox Ultra Light SS Pulley Kit
Crane Cams Vacuum Canister
Mugen Chipped P28 ECU
2 12” Eclipse Subwoofers
Kenwood 600 watt Amplifier (KAC-7295)
Pioneer Head Unit (DEH-536)
4 6 ½” Blauplunkt Speakers
Stinger 1 Farad Power Capacitor
TYC Taillights
APC Spoiler
TYC Headlights
Eurolight Fog/Spot Lights
Flip-Flop Trunk Lid
Falken Circuit Spec 17" Polished Rims
Falken ZE-326 Tires 215/40ZR17
Eibach Sport Line Lowering Spring 1.6” drop
Custom Painted Vents In Lamborghini Yellow
Old Jun 24, 2007
orlandomolina's Avatar
orlandomolina is an unknown quantity at this point
Re: Parting out my 95 Civic EX
can i get your radiator support?
how much?
