Taillights are not working....help me asap
Old Mar 10, 2007
element_2nice's Avatar
element_2nice is an unknown quantity at this point
on my 02 coupe, for some reason the taillight is acting crazy....
i mean when i press on brake the light doesn't come up in the back...
the right indicator is not working.....
i dunno wats wrong..'cause i checked the fuse on the bulbs and they look
alrite to me....so wats causing this???
this is really a major issue 'cause the lights dont go off when i press on brake...
however the only time the light works (minus right indicator and brake light) is when i turn on the headlights....
plz help me
Old Mar 10, 2007
sl33pyriceboi's Avatar
check the fuses again.
there are two sets of fuses, one under ur steering wheel, and one in ur engine bay
Old Mar 10, 2007
i checked the one which is under the hood and everything is alrite there...
but i cant seem to find the other fuse box......where exactly is it? n how do i reach it???
Old Mar 10, 2007
Rennen's Avatar
New Mod on the Block
since its under your steering wheel, you should start by taking off the panel... guess where... under the steering wheel.
Old Mar 10, 2007
2k1_Toaster's Avatar
2k1_Toaster will become famous soon enough
Ok, sounds like the little plunger switch thing on your brake pedal is broken. So the car doesn't know that the brake pedal is pushed.
I had this happen to me because I broke it off while installing my remote start...
It is a little white cylinder about 8mm diameter and a good 5cm long, inside a black casing on the back of the brake pedal. You can check it is this if you go under there and try to poke it yourself and see if the light comes on.
Old Mar 10, 2007
ok found the fuse box and checked...nothing seems to be blown or anything...
btw what number is exactly the taillight fuse??? just wanna make sure i didnt over look or anything....
Old Mar 10, 2007
well thats the only left to check i guess??? tried looking for it...but cant find it...will look harder again..
Old Mar 10, 2007
Actually I think it is on the front on the brake pedal. When you push it back, the plunger is allowed to release. It has 4 wires coming out of it.
Old Mar 10, 2007
heyy u got any pic of it???
Old Mar 10, 2007
checked everything....i dunno whats wrong here????
Old Mar 10, 2007
I can get you one...
Still need it?
Old Mar 10, 2007
yah i guess....i think i knw wat that thing looks like but still a pic wouldn't hurt...
but if thats also not the cause of the problem, then i wonder what it might be??
Old Mar 10, 2007
First take this off:
Then here are closeups:
Open:
Closed:
Closed by the arrow, and then the assembly with the wires is rectangled:
Old Mar 10, 2007
hmmm u might wanna resize the pics...lol its wayyy to big lol
Old Mar 10, 2007
and btw where exactly i m suppose to do poking???
Old Mar 10, 2007
Well most forums have the good sense to add a pic auto-resizer, and I already lowered the pictures resolution by over 4 times. They were over 4.5Mb each.
Better to get too much detail, then not enough!
Did that help any?
Old Mar 10, 2007
And do the poking on that little white part.
The white park should automatically push forwards when you press in the brake pedal. Then the brake lights should go on (while the car is on the on position). Push in the little white part, and the lights should go off. If that doesn't work, look at the wires on the back part. See if they are connected/loose. Trace it from the source, and that is the source.
Old Mar 10, 2007
Did that help any?
yep that really helped a lot...thnx for getting the pics n all...really applicate it...
its kinda late rite now, so i'll work on it 2morrow
will post results later
oh btw wat exactly did u break??? 'cause i dont understand why something could go wrong by the plunger, i have never even messed with that thing....
Old Mar 10, 2007
I was trying to get it off. I thought it would unscrew somehow so I had a pair of pliers as I was down there, and tried to get it out. Well the part that makes it work came out! But the black plastic piece was stuck.
I went to the honda dealership and bought a new one for about $10, and then I had to try and put it in. The old one was still stuck in there. I tried for about and hour to manuever it out. Then I gave up and got a hammer. I just smashed the things to little bits and it fell out. Then I popped in the new one. I still have no idea how to take it out. But to get it in, you just push it in, and turn a little bit and it clicks in.
Seems easy enough to reverse, but not for me!
