2 coilover questions
Old Jan 4, 2007
gyeah99's Avatar
gyeah99 is an unknown quantity at this point
1. After I install the coilovers and get an alignment, how involved is it to adjust the drop? Do I need to remove the wheels and turn a **** or what?
2. So after I do finally adjust the height (say for winter snow vs. summer time) do I then need to get another alignment? That would kind of be a pain to have to get an alignment every time I decide to adjust ride height.
Thanks!
Old Jan 4, 2007
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
1) It would depend on which coilovers you have. On some you use a spaner wrench to turn the collar under the spring (up = lower, down = heigher). Others you turn the entire shock body. Most of the ones for 7thgens you adjust height by the spring. The only one that I can think of that you adjust by the shock is JIC. The K-sports and Megans might be but I'm not sure. So in short it's more than turning a **** (any **** adjustment I've heard of, was to change damper firmness not height) and you most likely will have to remove your wheels.
2) You don't need to get an alignment but you should. Any change in height is going to change your camber angles.
Old Jan 4, 2007
gipperkid's Avatar
gipperkid is an unknown quantity at this point
^^what he said
Old Jan 4, 2007
Zzyzx's Avatar
Autocross Junky
More importanly, Ride height changes are going to change your toe settings... and Bad toe settings will eat tires 10x faster then just about any amount of camber. So yes, every time you alter the cars ride height you should get an alignment.
Old Jan 4, 2007
gyeah99's Avatar
Thanks for the responses ! Appreciate it. Looking at the tein SS kit as it seems popular....
Old Jan 4, 2007
robbclark1's Avatar
Retired suspension supermod.
SS changes height by moving the spring down.
JIC and megan offer independent height adjustment.
After you adjust you need a new alignment. My suggestion is to set it and forget it. Unless you really have to, don't adjust the height.
Old Jan 4, 2007
mugenman's Avatar
"mmmBAHHHH" - vtec y0
i love the tein ss's i think its a great coilover setup
GolNat
Jan 12, 2021 09:06 PM
SoslowEj666
Mar 8, 2016 01:10 AM
JKWood
Jul 28, 2015 03:45 PM
mHo2
Jul 27, 2015 12:57 PM
EM_WON
Jul 22, 2015 06:49 PM
