8th Gen 2006 - 2011.
Auto lock/un-lock
Old Oct 12, 2006
tamia's Avatar
tamia is an unknown quantity at this point
Auto lock/un-lock
In my manual (06 LX 5-sp sedan) it says you can set the doors to auto lock and auto un-lock with the drivers side door. I have read through the instructions several times and tried to set to Auto Lock to “on” but it does not work. I thought it might only be with the automatics but I’m sure the manual says you can set it with the manual transmission. Has anyone tried this successfully?
Old Oct 12, 2006
krstfrb's Avatar
krstfrb is an unknown quantity at this point
I have done it on our automatic ex sedan. If you are setting the auto-lock, first
turn the key on to accesories
hold the lock button down. you will hear the lock click, then a few seconds later, when you hear it click again, release it
turn the key to the off position within 5 seconds
To set the auto unlock, do the same thing as above, but hold the unlock button down instead
Good luck
Old Oct 13, 2006
Wadely's Avatar
Wadely is an unknown quantity at this point
May Only Work With Autos Since It Has A Switch Sensor To Lock When Shifted Out Of Park.
Old Oct 13, 2006
xxhaimbondxx's Avatar
xxhaimbondxx is an unknown quantity at this point
The car should of come with default factory setting which is: car locks whenever you reach the speed of 9 MPH or I believe 14 KPH and unlocks only the Driver's door whenever you put it to Park. That's for US. Canada might not have this option at all on the LX sedans. But in any case, my manual also mentions that you have to set your parking brake before you press the Lock/Unlock buttons.
Old Oct 13, 2006
Wadely's Avatar
Key Word Would Be "putting The Car In Par" Manuals Have No Park
Old Oct 13, 2006
I think manual trans substitutes "park" by turning the ignition off.
Old Oct 13, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
this is how it was on my pontiac grand am 5sp
Old Oct 15, 2006
Wadely's Avatar
maybe, i dont know for sure, i hate auto lock/unlock
Old Oct 16, 2006
Syr_Civic_06's Avatar
Syr_Civic_06 is an unknown quantity at this point
I have an 06 EX 5-sp sedan.
I have successfully set the doors to auto-lock and driver's door unlock by following the owner's manual. Be advised that auto-unlock ONLY unlocks the driver's door.
Old Oct 17, 2006
tamia's Avatar
Thanks! it works
With your suggestions, I tried again and it works. I don't really know what I did differently but it was successsful. Thanks to everyone who offered help.
Old Oct 18, 2006
jhwee's Avatar
jhwee is an unknown quantity at this point
Good luck
Is it possible to have all doors unlock when shifted to park in this? We have only sucessfully got ONLY the driver's door to unlock when shifted from D to P
solarpunk70
Apr 12, 2016 11:43 AM
Bruce2
Sep 27, 2015 08:45 PM
ttamrekab
Sep 25, 2015 04:41 PM
Skunkone
Sep 24, 2015 04:38 PM
