8th Gen 2006 - 2011.
Cabin Filter in 2006 - where ?
Old May 15, 2006
KRM's Avatar
KRM
KRM is an unknown quantity at this point
Question Cabin Filter in 2006 - where ?
Does anyone know where to find access to the cabin filter in the 2006?
In the 2005 it was in the glove box, but I don't see anything in the 2006
glove box.
Thanks,
Old May 15, 2006
imported_Mikey's Avatar
imported_Mikey is an unknown quantity at this point
There was another thread here about that.. I was sure they said it was in the glove box.
Can anyone confirm this??
Old May 16, 2006
KRM's Avatar
KRM
That was a post for the 2005 model.
Old May 16, 2006
pico's Avatar
pico is an unknown quantity at this point
Check the owner's manual. Im pretty sure its in the same spot. You drop your glove box past the stops and it should be staring at you. Ill check mine tomorrow.
Yep. Right behind the glove box. Even easier than the 7th gens.
Old May 22, 2006
imported_Tricky's Avatar
imported_Tricky is an unknown quantity at this point
so how come he couldnt find it in the glove box?
Is it tougher to see there now?
Old Jul 22, 2006
chuckseider's Avatar
chuckseider is an unknown quantity at this point
Cabin air filter
The owners manual tells you to take your car to your dealer to have the filter changed. It is behind the glove box and to change it open the glove box, squeeze the sides of the glovebox inward and it will swing out of the way. Press the 2 tabs on the filter towards each other and pull the filter out. It could not be easier to change.
Old Jul 26, 2006
KRM's Avatar
KRM
Thanks all,
It found it OK.I was a little afraid of breaking the plastic when bending the sides, but it worked fine.
rayaan_wasty
Sep 14, 2015 02:00 PM
John2009
Sep 10, 2015 09:53 PM
Christian123456
Sep 9, 2015 05:26 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
johnsoda
Sep 6, 2015 04:00 AM
