2004 Si - engine swap
So you'll go other makes of engine?
They would be expensive to fit most likely as custom engine mounts would need to be made up, among other things.
Im not sure what would fit comfortably but I have seen several SR20DET powered civics (Nissan Silvia engine).
K24A Swap!
No Offense!
If you are going to do a swap on the 04 you should go with the 2.4 liter K24A engine out the Honda CR-V. And if the displacement doesn't surfice, then you can to what Hasport Tuning did and slap a Jackson Racing S/C on it! Also they matched the engine with the Acura RSX-S's 6 speed manual transmission, with the Type R's LSD. This combo should put your HP to about 260! Now 260 ponies under the hood of a car that barely weighs 2700 pounds should put a smile on your face!!
Speaking of which i might have to do this swap myself!
Originally Posted by Shishpanik
The hatchback civic si 01 + all have a K20a3 i believe which is the same engine as in the base RSX. I'd say keep the engine you have which you can do alot to, whether you choose to do boost or N/A.
Originally Posted by CG99
I'd say supercharge it but thats just me
It would require some internal upgrades but not to the extent that putting a turbo on would.
cloudguy
Apr 28, 2015 05:02 AM
