Anyone who needs work done
Ok guys I’m trying to save up some money to buy a house so if anyone needs parts installed hit me up.
Some of the stuff I can do:
I/H/E Install
Audio Systems Including Fiberglass
Other Electrical
Aftermarket Parts
Suspension Work
Brakes
Transmission Work
Clutch Install
Scheduled Maintenance
Mechanical Problem Diagnosis
And More
All work will need to be done in my garage. I will provide all necessary tools. The OEM Service Manual torque specs will be followed (I’m not an impact artist). I will treat your car like my own. I have done many installs and have a lot of experiance with 7th gen Civics (I rebuilt my GF's 02 Auto trans with a TCI Racing Kit).
PM me for more details and prices
I/H/E Install
Other Electrical
Aftermarket Parts
Suspension Work
Brakes
Transmission Work
Clutch Install
And More
Its a celebration bitches!
works for me.
u avail. next Sat early afternoon ... ?
yeah. should be pretty straight forward. tranny is on the driver's side ... u know the deal.
;P
oh damn. actually, while you're at it, wanna do an oil change too? haha. k20 oil changes are REALLY easy. you can easily remove the filter from the top ... no need to go under the car except to drain it.
;P
OOh and Darek you have PM
soooon to be psshh
how much do you charge to rebuild a MT tranny? i dont know if its just my clutch that needs replacing or if my entire tranny is ****ed. my car sounds like a coffee grinder
i need to get my oil pressure and vacuum gauges wired up (the pod is already installed). please help me with this before the 27th because thats when I leave the town. I'm located in 90212. Lemme know. Thanks!
Sorry guys for not responding to the last few requests. I’ve been super busy doing this ^^ and a few other things so ya. Hit me up if you still need help
Ok here is a list of a few of the things I've done recently with SpoonEM's help.
1 Manual trans Input shaft bearing
1 Auto trans rebuild
2 Engine replacements
3 Clutches
3 Clutches
Seriously though, if anyone needs this work done, we get it done pretty quick. Just ask Kimchi. We did his clutch, input shaft bearings (which requires tearing apart the tranny) and got it all back in and running in only a couple hours. So if youre hurting for time, its not a problem. So let us know.
