Car Audio box help/ideas!!
Hey guys, I need some help. I have a Memphis M3 15" Sub (M1354D) and right now I have a box built for it that was made by memphis. The problem is that the box is too big for my (our) trunks and i have to lay it so that the sub fires up. It wont lay the proper way so that the sub fires towards the trunk. So I was thinking of building a new box. I dont know where to start. Here are the specs on my sub
http://memphiscaraudio.com/LiveImage...cumentURL2.pdf
Thats the recommended enclosure size
http://memphiscaraudio.com/LiveImage...cumentURL1.pdf
Thats the specs on the sub
I want to build a box where it will fit in the car and still give me some room for other things. I either want the sub to fire towards the cabin or towards the trunk. If i fired it towards the trunk i would put plexi glass on the back of the box so that you could see the magnet and line the inside with blue colored mirrors and put in 2 blue led bars inside. If i built it firing towards the trunk I would build a regular box with no plexi glass and put it in. Then i would cut out and ellipse shaped piece of wood and lay it from one end of the trunk to the other width wise and wrap it in blue vinyl to match my car. That way it would hide the empty space around my box plus give it a custom finished look.
I dont really know to much about building box's to specs but i really want to learn so im asking if anyone knows how to do this and what the dimensions would have to be. I can build any kind of box be it fiberglass or whatever.
If you guys have any ideas or thoughts give me a shout out, ill take any help/thoughts i can get. If you dont understand ill try my best to explain things better.
I hope you guys understand the jist of what im trying to say.
Airheadsman2k3
Heres kind of a brief concept of what i was referring too
Airheadsman2k3
Last edited by Airheadsman2k3; Aug 26, 2006 at 07:40 PM. Reason: Automerged Doublepost
EXWisdom
Nov 5, 2001 10:24 PM
