Amping my aftermarket speakers
Old Aug 2, 2006
mp3allday's Avatar
mp3allday is an unknown quantity at this point
So i have these two sets of speakers actually the older models but there the same wattage, but i was wondering what kindof amp or amps i should get to power them right now there running of my avh-p6600 deck which puts out about 50 watts a channel
http://www.pioneerelectronics.com/pn...642573,00.html
http://www.pioneerelectronics.com/pn...562745,00.html
Old Aug 2, 2006
cannonfolder's Avatar
cannonfolder is an unknown quantity at this point
I'm not sure what your bugget is but as for myself, I don't mind spending a little extra for quality so that in the long run I don't regret it. I'm not an expert in audio but I can definitely recommend the 300/4 JL amp. Not the most powerful, but the quality sound is great.
http://mobile.jlaudio.com/products_amps.php?amp_id=254
Old Aug 2, 2006
HondaKorn's Avatar
Life is better with 5lug
the watts per channel is actually 18-22rms.....the 50 is just the max output. A 100 watt rms amp shout be fine for 2 speakers.
Old Aug 2, 2006
50 watts a channel haha try maybe 15-20. you look at rms watts not peak. look at the speaker rms what they can handle, then amp them with at least 1/2 that. ex. i have infinity ref max power 60w and i have a 4 ch amp thats 30wx4.
Old Aug 2, 2006
mp3allday's Avatar
Ok guys i got some good idea's thanks for the help
This is the amp i currently have
http://www.rockfordfosgate.com/produ...3&locale=en_US
So this would probably be to much for all 4 speakers
I want to try and stick with rockford because thats brand i have for my sub and hopefully the same look as well
http://www.rockfordfosgate.com/produ...5&locale=en_US
Old Aug 2, 2006
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
What kind of amp are you running, gear? I have the same speakers in my coupe.
Old Aug 2, 2006
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
well the amp you have right now could only power 2 speakers or a single sub, you couldn't power all four with it. The Rockford 4004 is a good amp, I have the older model which is a 400X (4 channel) and a 201S (2 channel) powering my sub. Just a word of advice tho, don't go with an amp by how it looks. Chances are if your just using it commercially you'll mount the amp on the sub box and won't even see it. Check out JL, they make good stuff too.
Old Aug 2, 2006
i just have the old mrp-f240
Old Aug 3, 2006
mp3allday's Avatar
Well I want a sub that looks the same because i have built a floor for my trunk, i have mounted my amp in front of the sub closer to the opening sunk into the floor. So if i get another amp i want to mount close to that one thus the reason i want them to look similar, they are going to be the focal point of my trunk.
So do you guys think that the Rockford 4004 will blow my speakers
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
bhollie
Sep 22, 2015 11:08 PM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
