Re-sealed headlights..still fog up...
Old Aug 1, 2006
kornsined's Avatar
Man i re-sealed my headlights, what i thought was a good seal job, and they still fog up. actually even worse now. is there something i'm doing wrong? wrong silicone or what?
Old Aug 1, 2006
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
what kinda silicone did you use, and did you use a heat gun?
Old Aug 1, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
did you make sure you got all the mostier out of the head light already?
Old Aug 1, 2006
05civicexse's Avatar
05civicexse is an unknown quantity at this point
set the whole headlight in the oven for like 3-4 minutes at 200 f degrees. and then push them together and it will seal better.
Old Aug 2, 2006
Nyte's Avatar
Nyte will become famous soon enoughNyte will become famous soon enough
I dunno man, when i cleared my lights. i just cleaned the inside and glued it together with bathroom clear silicone. i didnt have any trouble. i put two layers in case of leakage. but i gotta take it apart again cuz i didnt clean it as good as i thought. but i would say take it apart again, and clean it up and make sure its FULLY dry. then re-glue it, and put like 2 layers of silicone on it. but make sure the first layer is dry so u dont accidently get some inside ur headlights like what i did. and take your time and dont rush or it'll look like crap. gl
Old Aug 2, 2006
Honda_Inspired's Avatar
Honda_Inspired is an unknown quantity at this point
Where did you apply the sealant??? It happened to me before; I thought I had it sealed right because I put LOTS of silicon and it ended up fogging after a car wash. I figured out what I did wrong - I just put the headlights together and applied sealant around the edges rather than the INSIDE GROOVES. After taking the headlights apart, I put a GENEROUS amount of silicon in those grooves, there has been no fogging whatsoever.
Old Aug 2, 2006
kornsined's Avatar
that must be what's going on. I used kitchen/batroom silicone. I guess doing just the edges doesn't cut it. Well i'll try it again. thanks for the heads up guys.
Old Aug 2, 2006
varner88's Avatar
...JeRsEy sTyLe...
varner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of light
i never had a seal problem i put mine back in the oven and re used the oem glue worked better then my previous silicone job and looked stock
Old Aug 2, 2006
just make sure the sealant is waterproof silicone (clear). when i seal my halos once and for all, they're going in oven first to use the stock goo, which isnt much. then im going around all the edge with silicone letting dry 24hrs and then doing second layer around the first. be sure to let it cure full 24hrs. its very easy to miss a tiny hole and then all the vapor comes in. also make sure the bulb sockets are closed. i know some have vents, especially projectors, not necessary. seal up around the sockets too while you're at it. you can always break the seal when you change a bulb later.
UltraHDGames
Jun 8, 2016 05:16 PM
Dawit Melese
Oct 4, 2015 08:02 PM
mrwhos
Aug 11, 2015 02:03 AM
j-chest
Jul 31, 2015 01:18 PM
Enigma346
Lighting
Jul 12, 2015 08:24 PM
