05 civic shift boot removal.
Old Jul 29, 2006
honda123's Avatar
honda123 is an unknown quantity at this point
Im just wondering can u take off the shift boot withought taking out the center console?. If so can some one explain how to do it. Thanks in advance.
Old Jul 29, 2006
ramcosca's Avatar
Words on a User Title
A little click on this button would have given you lots of things...
And to quote one of our mods...
Originally Posted by dj02
this is why we have a DIY section
Removing The Shift **** Off A Manual Transmission by... uhm... Forum Bot
Old Jul 29, 2006
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
pull down the on little silver piece under the **** until it comes loose. unscrew the ****. grab the black plastic piece the boot is attatched to and rip that bitch straight out of the console.
Old Jul 30, 2006
honda123's Avatar
So if i rip it out can i put it back on like how it use to be ?
Old Jul 30, 2006
yes. it has 2 clips on the top by the cup holders and 2 on the back next to the console. stick your hand in the hole the shifter comes out of and yank the **** out of it.
Old Jul 30, 2006
honda123's Avatar
Alright ill try it out thanks everyone for the help. Hopfully its as easy as it sounds.
Old Jul 30, 2006
if you cant get it, take it to a shop. HAHAHAHAHA
Old Jul 30, 2006
honda123's Avatar
yea i cant find those clips ur talking about man got any pics??
Old Jul 30, 2006
ramcosca's Avatar
Aye, the shift boot, you said. Hold on...
Ok, got this for ya. Only posting the things you need.
Originally Posted by cubanmike26
So I was bored and decided to take on a simple project I was thinking for some time. Type R shift boots aren't that expensive, but if you have the time and a sowing-machine you can make your own at home.
Note: If you don't have a sowing-machine, you can still do it using a needle and red red fabric. It's only going to take a little longer, but it may come out even better.
Here's the DIY:
Tools:
1. a pair of pliers
2. ...
3. one cable tie
4. screw driver
5. home depot staples
1) Remove the shiftboot assembly from the center console carefully with a flat screw driver. (If you are not sure how to, check the DIY section on how to remove the center console). You ONLY need to remove the shift boot assembly, not the whole center console.
2) Once you've done that, you should have this:
3) Flip the boot around and cut the plastic cable tie with a pair of pliers (carefull not to damage the boot). Remember how it goes for when you put it back together.
4) Next, straighten the staples' tips with the pliers and remove them from the other side:
And for the reinstall...
Flip the boot around, insert a new cable tie to attach the boot to the plastic thingy like it was before you took it off.
8) Finally, insert the bottom tips of the boot like they were inside the plastic before you removed the staples. Put new staples on and bammm!!!! you got a type R shift boot made at home
9) Now simply assemble everything back together and you are done.
Hope that helped. Sorry for the misunderstanding the first time.
Old Jul 30, 2006
EM2_FRESH's Avatar
EM2_FRESH is an unknown quantity at this point
nice DIY..
PS is there suppose to be an open space there..^^
Old Jul 30, 2006
ramcosca's Avatar
No. He just took the pic without having finished it. Lazy ***!
Old Jul 30, 2006
honda123's Avatar
thanks man . i got it too work.. ill post pics up soon thanks
Old Jul 30, 2006
ramcosca's Avatar
Sah-weet!
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
dragonsblood
Apr 27, 2015 12:28 PM
EC3
Apr 22, 2015 07:55 PM
toastyghosty
37
Jun 10, 2002 01:07 AM
toastyghosty
32
Dec 26, 2001 02:03 AM
