how to widen/cut speakers hole on door?
Old Jul 20, 2006
joey_kev's Avatar
joey_kev is an unknown quantity at this point
i got a civic sedan 2002, i'm trying to fit a 7" midbass on the door but the speaker hole is incredibly small... I was really surprised when the door trim were off, the hole is much smaller than most of the cars I've seen
even the back of the magnet does not fit into the hole
is there anyway to widen/cut them? what tools do I need?
even better, if anyone has tutorial with pretty pics that would be great
Old Jul 20, 2006
Nasdurus's Avatar
Nasdurus is an unknown quantity at this point
Not really a whole lot special you can do. Measure the whole and cut it. Airsaw or air hammer would be the fastest and easiest way. Taking into account you don't have air tools, a recip saw should work out as long as you have a blade to cut metal. I'd make sure the depth of the speaker fits before the hole is cut.
Also check the door trim panel. Say you cut your hole and mount your speaker in it. Go to put your trim panel back on and the panel doesn't fit over your new widdened hole as your speaker sits too far out and the trim can't fit flush with the door. Or worse the panel clips down on the speaker damageing it. Goodluck
Old Jul 20, 2006
James77's Avatar
James77 is an unknown quantity at this point
Instead of cutting your door you could also install an MDF spacer. You will most likely need a spacer anyway depending on the mounting depth of your speakers.
Old Jul 21, 2006
jbirn's Avatar
jbirn is an unknown quantity at this point
I put 6.5" Infinity Kappas in my doors and it took quite a lot of work. I bought some 2" spacers that I had to cut down to just over an inch in order to get things to fit properly. After getting the speakers mounted the panel didn't quite fit on properly so I had to cut down some of the plastic on the speaker area of the panel. It's quite rigged but it was worth it. I just don't think Honda wanted us to have aftermarket speakers.
Old Jul 21, 2006
PopcornPlaya's Avatar
Electric Boogaloo...
Rotozip or dremel is the easiest way, and it won't leave burrs like a saw or airchisel/hammer would. The way it turns, it leaves a fairly smooth surface, and edge. You'll still need a spacer/baffle unless it's super shallow. Easily made from a piece of scrap MDF.
beeemerdude
Jul 23, 2015 03:53 PM
Nalmonte
Jul 22, 2015 09:08 AM
ballmich
Jul 9, 2015 11:59 AM
Spanky4269
Jul 5, 2015 09:40 PM
