Can I Fit 2 15inch Speakers Here
I have a question do you guys think I can fit 2 15inch speaker behind the rear seat facing me...
Im going to try something with my cuz to fit them... I bought two electro voice speakers and I want to put them on badd lol
Trust me man. Don't waste your time and money. It will not fit. I know you did the measurements and everything, and technically, it does fit according to the measurements. But you forget that the entrance to the trunk is not big enough to actually put the box inside.
If you put false wall and put them there, it will sound like crap! I've been using 15s" for years with many different boxes and even without boxes.
The only way i can think of is to build two different box. Each one has to be very carefully measured. From my own experience, a ported box built with factory reference is the best.
Besides fiberglass, this is probably the only way. This is a civic anyhow, and throwing 2 15s" will take some work. Let me know what you plan.
spell check pwns you
edited**yes you can and youll get a back massager outta it also. have to relocate the N2O though. making a setup?
Originally Posted by tuner04civic
you can get it to fit may have to pull out some parts. but you can but will add alot of weight and youll loose the backseat. may look good to curve them across the backwall in trunk.
BTW i'm working on my trunk right now, i'll post some pics if you want and show you what i mean.
i didnt see keeping the rear seats. he took the shot im thinking he wants it in the back. my bad. im talking about the back plastic pieces. but if its going in the trunk its possible to fit 15's.
i just finished mine the other day 2 12's with space to get to spare tire.
All Show No Go Sedan
It is possible. I used to have 3 cheap 12's too running on 1.0 cubic ft each. I've never used 15's so I wouldn't know how much space you would need, but probably a lot if you want it to hit low.
Do it IB - means you have to completey seal the trunk airspace from the passenger compartment. Then the trunk itself is the box and you can mount the subs firing into the passenger compartment on a piece of MDF.
Biggunschad
Sep 11, 2015 04:06 PM
Ultra Havoc
Sep 9, 2015 10:58 PM
redcloud
Sep 7, 2015 01:45 PM
