Big brake kit 16" rims will it fit?
Old Jul 14, 2006
umboutwo's Avatar
umboutwo is an unknown quantity at this point
Just wondering if anyones fit the brembo 315mm brake kit with 16" rims?
Can it be done or do you have upsize to 17" rims?
Old Jul 14, 2006
greenEX's Avatar
greenEX will become famous soon enoughgreenEX will become famous soon enough
Yes, should fit.
Old Jul 15, 2006
umboutwo's Avatar
Do you have the 315mm kit on your car with 16" rims?
Old Jul 15, 2006
ryangt's Avatar
ryangt is an unknown quantity at this point
i have the AEM big brake kit behind my 16s its a close fit but it fits no problem. THe aem one required that i remove a bit of material from the caliper to install them properly tho, so just keep in mind that they might not exactly " bolt up "
Old Jul 15, 2006
greenEX's Avatar
click the link
Old Jul 16, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
12.4" rotors+4 pots under a 16" wheel? doubtful. The AEM kit uses the stock calipers which are far thinner than a 4 piston will be.
Old Jul 16, 2006
ryangt's Avatar
true true, the tolerences were damn close just on the aem one, and like he said tis meant to go on the stock hub. Good luck with yours. Why are you wanting such a hefty kit anyways? The big brake kits dont do **** on the street, they are just expensive and look pretty. I had better braking with my powerslot/hawk pads combo, i only run the aems now cuz they we picked up cheap and i figured id give them a shot, but id never use another big brake kit again.
Old Jul 17, 2006
Vantage's Avatar
Vantage should not be trusted
it will be a lot different as he will have upgraded calipers, and the AEM uses stock calipers.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Poopies
Apr 20, 2017 11:36 PM
bsmiley
Apr 27, 2015 01:27 PM
