someone please help
Old Jul 12, 2006
mclean987's Avatar
mclean987 is an unknown quantity at this point
someone please help
my car keeps messig up my ecus i changed it twice and now its the same thing what could be causing this the alternator ?
Old Jul 12, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
what do you mean messing up?
Old Jul 12, 2006
mclean987's Avatar
ok rpm guage doesnt work, temp guage doesnt work, car wont rev over like 2k and ecu has a clicking noise the battery light stays on for first 10 seconds aswell i changed the ecu today got honda to program the key then 15 mins later the same thing happened messed up my brand new ecu i dont know what to do what could be damaging the ecu ?
Old Jul 12, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Change the alternator. I and 1 other member experienced the same thing. Except ours wasnt continuing to break. Better to be safe than sorry. Good luck.
Old Jul 12, 2006
You havent wired anything else into the car have you?
Old Jul 12, 2006
mclean987's Avatar
oh really what did you do to fix it ? couldnt it be something apart from the alternator i wasted $200 today buying new ecu and programming it now i need another, are all alternators in 01-05 the same?
Old Jul 13, 2006
dj02's Avatar
why would this be the alternator? i say take it to shop this is sounds like a big problem.
Old Jul 13, 2006
mclean987's Avatar
thanks for reply it is a big problem it happened after i changed engine im guessing its the alternator just gonna change it because i got one cheap i dont know what else it could be ?? but shops wants atleast $150 for 2 hour labor diagnostic and they might not even find problem, the car still drives though after the ecus get messed up but ecu wont give out any codes, rpm wont work or temp guage and car wont rev over like 2000rpms starts breaking up, all i have on it is intake, header and exhaust
Old Jul 13, 2006
What do you mean changed the engin? Did you do a swap from an A1 to A2? Did you get the right year engine?
Old Jul 13, 2006
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
Swapped engine?
Which one?
If you swapped to a different engine and didn't change with an appropriate ECU, then there you go...
Old Jul 13, 2006
mclean987's Avatar
i swapped the same engine to the same one d17a2 someone correct me if im wrong isnt 01-05 civic ex the same engine so the year doesnt matter
Old Jul 13, 2006
djmota's Avatar
could be a bad engine harness. did you use the harness from the new engine or did you reuse your old one?
Old Jul 13, 2006
mclean987's Avatar
i used the old harness and car was running fine b4
Old Jul 13, 2006
well the are buy they arent for it to be legal it has to be same year or newer. but i thought something in the ecu changed..
Old Jul 13, 2006
mclean987's Avatar
i thought they were the same does anyone know this info ?
Old Jul 13, 2006
mclean987's Avatar
Old Jul 15, 2006
XSRCivic's Avatar
The tensionor bolt on my alt broke, it made the alternator send a surge through the electrical system which semi-fried the ecu causing the same problem that you are having. Fortunatley my alt was still working properly so i didnt need to change it. Your alt is doing the same thing. Changing that out is the cheapest route right now besides getting yet another ecu to reprogram.
Old Jul 15, 2006
mclean987's Avatar
thank you very much thats what im gonna do, ordered it already, just wondering is there anything else that could cause this, was your ecu clicking and same symptons i described? temp guage and rpm not working
Old Jul 15, 2006
XSRCivic's Avatar
yes, exactly. the car runs real bad like strugles to accelerate. It starts clicking at first for about 12 seconds then all the gauges shut down and the car runs real eratic. It sucks now that you have to get another ecu AND replace the alternator. I really do think that should end the problem. Did you replace the alt or remove it for any reason? Have you checked it to see if it is secure, all wires intact etc?
Old Jul 15, 2006
mclean987's Avatar
i just purchased alternator havent done anything yet, so the ecus are damaged? i cant get them to work again have to change ecu? did you change your ecu aswell, yeh it sucks im spending so much money, did your speedometer still work?
Old Jul 15, 2006
XSRCivic's Avatar
I didnt bother trying to get it repaired since I had another one already. The only thing on the dash that worked was the speedo, if I recall. You or whoever replaced the motor may have mounted the alternator incorrectly or a bolt is loose or whatever. Check all your alternators connections make sure they are tightened properly, nothing dangling where it shouldnt be and double check ALL your mounting/tensioning bolts make sure they are secure but dont overtighten them. Check with Honda to see if there is anything they can do with the damaged ECUs. Mine wouldnt even communicate with there scanner , Let me know what happens.
Old Jul 15, 2006
mclean987's Avatar
mine did the same thing wouldnt communicate with scanner im gonna change alternator and see what happends i dont see anyting loose
Old Jul 15, 2006
XSRCivic's Avatar
well changing the alt wont solve the problem alone. You need to get another ecu put in too. Unless that is what you were talking about.
Old Jul 15, 2006
mclean987's Avatar
yeh i know that sucks gonna do tjhat after i change alternator
Old Jul 15, 2006
Morton's Avatar
Make friends with your slow.
Morton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud of
THAT WAS MY FIRST GUESS THATS WHAT THE PROBLEM PROBABLY IS. THIS GUY NEEDS A NEW WIRING HARNESS LIKE TOMORROW!
Old Jul 15, 2006
mclean987's Avatar
harness is fine i used the old one, that wouldnt explain why car runs great for like 15 mins
Old Jul 18, 2006
Jdm01Em2's Avatar
Jdm01Em2 will become famous soon enoughJdm01Em2 will become famous soon enough
yo im that other member that had the same promblem that XRS said this is the worst sit. i have ever delt with, with any car make sure your alt. is tight then new ecu and the reflash that what happened to mine and it worked but i think XRS was tellin me he had to reflash his ecu in a nother car not your sure but good lucj
