WW Side Skirts coming off :/
Old Mar 5, 2002
Strychnine's Avatar
Strychnine is an unknown quantity at this point
The little stickie things that hold on underneath the door seem to be loosening, so the body kit is pulling away from the car. Of course it's not falling off, cuz it's screwed too...anyone have a solution to this?
Old Mar 5, 2002
silvervtec01's Avatar
silvervtec01 is an unknown quantity at this point
unscrew and remove skirt, add more STICKY THINGS, replace....should work fine
Old Mar 5, 2002
Dakker's Avatar
Giggity Giggity
Dakker is an unknown quantity at this point
hehehehe, superglue!!
Old Mar 5, 2002
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Yeah remove your sideskirts. THEN make sure you remove all of the current "STICKY THINGS" from your sideskirt and car. And clean it well. Then go and get yourself some more STICKY THINGS at a hardware store. It's 3M double sided tape, heavy duty or somethin' I think. It's gray. You should be ok. If you have trouble removing the gunk from your actual car (which I doubt) you can try GOO GONE or mineral spirits. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 5, 2002
Strychnine's Avatar
I was hoping I wouldn't have to take them off, but ah well...the price we pay for beauty...
Old Mar 5, 2002
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Just like SpdRcrChk said. 3M also makes a product called 'adhesion promotor', but i cant remember the number right now. You can get it in little packets with a sponge to apply it, but it may be hard to find. Call some automotive paint supply stores. You wipe down both surfaces with it before sticking the tape to it. It makes the 3M foam tape stick REAL well. Oh, and if you do have trouble getting the existing tape off with chemicals, you will have to RUB it off with your thumb.
Old Mar 8, 2002
yeahdanny's Avatar
yeahdanny is an unknown quantity at this point
two words : Liquid Nails
1slo2k1civic
Nov 21, 2001 11:07 AM
3rdcivic
Oct 24, 2001 12:19 PM
eX2ooo
Oct 5, 2001 12:19 AM
ernhole1
Aug 2, 2001 11:12 PM
