40 or 35 on 18's
Old Jun 13, 2006
zik_zivik's Avatar
New Member
zik_zivik is an unknown quantity at this point
Question 40 or 35 on 18's
hey y'all, i want to get some opinion on which one is better for my car..
I have a 02 civic sedan, 1.5 inch dropped on 17 inch rims (215/40/17)..
Im planning to upgrade to 18's with 215/40/18 on them.
Some said that i should put 35's instead of 40's to avoid rubbing.
What would you suggest?
help pls... thanks...
Old Jun 13, 2006
phuviano's Avatar
Slowest 7thgen in the GTA
35's would most likely not rub at all, and 40's may or maynot rub depending on your setup.
I have 205/45/17's, and most people said it wouldn't rub at all. My tires were rubbing, but only in the rear. It only rubbed when going over certain bumps on the road. if I were you, I'd probably stick with 35's. There will be more wheel gap, but you mostly likely won't rub at all.
Old Jun 13, 2006
texascivic2k1's Avatar
THE LONE STAR STATE
texascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of light
I have 18" - 35 tires with Tein-S-Techs (1.5" drop) in the front... and have no problems rubbing.
Old Jun 15, 2006
FALKEN's Avatar
Civicforums Junkie
http://www.7thgencivic.com/forums/sh...87#post3857087
