Looking for Boost..come on in!
well I have decided to buy another car and will not be installing my turbo kit. Most of this custom kit is still BRAND NEW as in NEVER BEEN USED. It is 95% complete
-T3 Turbo Manifold flanged for 38 mm external wastegate (BRAND NEW) (Retains A/C)
-T3 (.42/.48 spec) Turbo, Garrett Internals (BRAND NEW, NO SHAFT PLAY)
-38 MM Wastegate (Slightly Used) with 4.7psi spring and 10 psi spring
- 2.5" Aluminum Universal Intercooler Piping Kit with Calmps and Couplers (BRAND NEW)
-FMIC 2.5x7.5x28 (BRAND NEW) 2.5" end tanks
- T3 Oil Drain and Feed Flanges, Gaskets (ALL BRAND NEW)
- Brand New Braided Oil Feed and Drain Lines
- RSX-S Injectors 310cc (USED W/ TINY CHIP OUT OF 1 INJECTOR) Car still runs fine when tested
- Greddy Emanage w/ Support tool and cable (Used for 6 months)
- Full P&P Emange harness w/ all harness for any 7th gen Civic (Brand new but had to replace 1 pin..works great)
- Boost, Electric Oil Pressure and Narrowband A/F Autometer Sport Comp Gauges (used for 6 months)
- Golden Eagle Oil Block Adapter (BRAND NEW) Works with both the above oil line and oil pressure gauge!
- OEM Exhaust Gasket - Brand New Unsealed
- TYPE RFL BOV, Brand New
-$2000 takes the pot + gauge pod + all misc bolts, clamps, connectors and couplers you may need
PICS AVAILABLE
MOST ITEMS BRAND SPANKING NEW!!
Pms Replied To...lots Of Intrest
PICS AVAILABLE
Last edited by lovinthevtec; May 30, 2006 at 06:58 PM. Reason: Automerged Doublepost
Located in southern ontario, dont really have the time to install due to working 6 days a week..sorry
All PMS replied again...lots of intrest in the setup
And from first hand knowlage let this be said: IN THE LONG RUN IT IS CHEAPER TO BUY A WHOLE KIT THEN INDIVIDUAL PARTS!!
