rsx rear sway and evo2 exhaust
Old May 18, 2006
familycar's Avatar
i know the topic of rear sways and aftermarket exhaust has been beat to death but i just searched through 6 of the 15 pages of threads regarding rear sways and i still did not get the answer i am looking for. basically i am trying to see if anyone with a 01 lx sedan has installed a 19mm rsx rear sway with an evo2 exhaust. i am trying to determine if the rsx rear sway has the same problem as the progress rear sway with rubbing and vibrating on the exhaust piping i really dont want to modify the exhaust but i really want a rear sway i cant stand how the rear rides up on a fast corner. i do have semi soft springs(eibach prokits) but i dont want anything bigger than the 19mm.
Old May 18, 2006
eye_see_you's Avatar
let the devil out
it will work I had a 22mm rear sway with the evo2 exhaust also had tokico hp struts and the same springs as you
Old May 18, 2006
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
Are you going to use the progress adap kit for the 01 or are you going to do the custom work to mount the sway bar?
Old May 22, 2006
familycar's Avatar
i don tknow yet it is still up in the air i can have a solid piece of aluminum cut to fit pretty easily and then drill my own holes. that would be simple so i guess it depends on how much i can pick up the progress adaptor kit for vs having one made
JohnnyBxo
Nov 12, 2015 03:04 PM
Misfit2613
Jul 30, 2015 09:49 AM
fordover
Jul 11, 2015 09:10 PM
hayden55
Jul 8, 2015 11:38 PM
fvckbg
Jul 7, 2015 07:08 PM
