Looking For the right AMP
Old Apr 3, 2006
I3ananaFoo's Avatar
I3ananaFoo is an unknown quantity at this point
Exclamation Looking For the right AMP
I just got an Infinity Sub (KAPPA PERFECT10VQ)
Power Handling, Peak: 1600 Watts
Power Handling, RMS: 400 Watts
Sensitivity: 87dB
Frequency Response (±3dB): 25Hz - 400Hz
Mounting Depth: 6-1/2"
Impedance: 4 Ohms
And i was planning on getting an Alpine AMP (MRP-M650 Class-D Mono Power Amplifier)
# CEA-2006 Power Rating (40hm@14.4V = 1%THD+N), S/N 65dBA (Ref. 1W into 4Ohm): 400W x 1
# RMS Power (at 14.4V THD+N, 20Hz-20kHz):
* Per channel into 4 ohms: 400W x 1 (0.08% THD)
* Per channel into 2 ohms: 600W x 1
* Bridged 4 ohms: 1000W x 1 (0.3% THD)
# Bass Engine Sound Tuning:
* Crossover Frequency : 50Hz - 400Hz LP (-12dB/oct)
* Subsonic Filter (Fixed): 15Hz
* Bass EQ Frequency (Fixed): 50Hz +12dB
# Frequency Response: 20Hz - 200Hz (+3,-3dB)
# Signal to Noise (S/N): 90dBA (Reference to Rated Power)
# Input Sensitivity (For Rated Power): 0.2V to 4.0V (1.0 at Center Detent)
# Input Impedance: 10k Ohm
# Speaker Impedance: 4 or 2 ohm Bridged
I was wondering for any other suggestions
Old Apr 3, 2006
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
Infinity Reference 611a
Performance
RMS Power Output (Watts x Channels) 456 x 1
Frequency Response N/A
THD at Rated RMS Power 1%
Signal to Noise Ratio 70 dB
Input Voltage 14.4v
Peak Power Output (Watts x Channels) ---
Power at 2 Ohms (Watts x Channels) 657 x 1
Bridged Power (Watts x Channels) N/A
Minimum Impedance Bridged N/A
Minimum Impedance Unbridged 2
Features
Amplifier Class D
Tri-Way Capable No
Low-Pass Crossover Frequency 32-320 Hz
Low-Pass Slope (dB/octave) 12dB
High-Pass Crossover Frequency N/A
High-Pass Slope (dB/octave) N/A
Bass Boost DBO level up to 12dB
Bass Boost Frequency DBO freq 20-80 Hz
Fan Cooled No
Fuse Rating 30 x 2
Speaker Level Inputs No
Preamp Outputs 1 pair
LED Power Indicator Yes
Height (inches) 2-11/16
Width (inches) 15-7/8
Length (inches) 12-1/8
Parts Warranty 1 Year
Labor Warranty 1 Year
Old Apr 4, 2006
msi1337's Avatar
msi1337 is an unknown quantity at this point
http://cgi.ebay.com/HIFONICS-ZEUS-ZX...QQcmdZViewItem
HIFONICS ZEUS ZX4000 2-CH AMPLIFIER
Specifications :
New HIFONICS twentieth Anniversary Heat Sink Design
2 x 100 Watts @ 4 Ohms
2 x 200 Watts @ 2 Ohms
1 x 400 Watts @ 4 Ohms
Bass remote with blue LED power on & indicator included
Ultra Fi Mosfets
Zeus EXVP
Hifonics Surface mount design
Fully adjustable accu-cross X-overs
PWM mosfet power supply
Line output for amp daisy chaining
Variable Bass EQ
Sub-sonic filter
4 gauge power connectors
Class AB operation
Maxi fuse
Old Apr 4, 2006
RangerMan's Avatar
RangerMan is a jewel in the roughRangerMan is a jewel in the roughRangerMan is a jewel in the rough
I am biased totally
Nak
on Ebay
Old Apr 5, 2006
BrynDN's Avatar
BrynDN should not be trusted
I highly recommend MTX amps. Their manufacturing process for car amps is much better than most. (although you can't go wrong with a Nakamichi, for the extra dough).
Old Apr 6, 2006
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Although I appreciate the specs you gave in your post immensely, you left out a crucial bit of info - How much are you willing to spend, and what do you wanna get out of it? Are you willing to spend arc or zapco money? JL Audio 500/1?? You wanna stay more reasonable in price, like
http://www.onlinecarstereo.com/CarAu...roductID=12982
Old Apr 6, 2006
kumanan's Avatar
kumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the roughkumanan is a jewel in the rough
JL, kicker, phoenix gold, RE audio, Earthquake. Nothing else
Old Apr 6, 2006
J187's Avatar
Nothing? Not even Tru, Arc, Zapco or Mac?
Old Apr 6, 2006
RangerMan's Avatar
Zapco is like a forum favorite on elitecaraudio and canadiancaraudio.
Old Apr 12, 2006
I3ananaFoo's Avatar
I really wanna spend around 300
Old Apr 12, 2006
Pickles's Avatar
Pickles is an unknown quantity at this point
the best amp company is US AMPS i got my directly from a dealer so i paid less i thi nk they run about 600 but are welll worth it.
Old Apr 14, 2006
diskreet's Avatar
Generally you will get what you pay for with amps. If you get a high proced amp to put with your Infinity sub (like JL, alpine, infinity, etc.) you will really love the clarity you have. And having such a nice sub helps too
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
