Cluster removal - help please
Is there a trick to getting the black surround off? I know you remove the two screws at the top then yank...but the bottom just won't budge. Are there other screws or clips holding it down? I want to get to the cluster behind
thanks to this thread i was also able to remove the bezel. although im having a hard time switching wires... the wire wont come off of the connector
i've hear an "extraction tool" is needed but we dont have such here.
Don't just yank on the wires you'll strip them or rip/break them right off the connecter which will require you to solder them back on.
Get an extraction tool at a hobby store or you could use a small and long needle to push the tabs down and push them out.
Crack kills... But then again... So do I...
there are little clips on the sides of the harness. You need to use a small screwdriver to pop this off, once you do, with a little force you can pull them out one at a time with your hands no tools needed.
fatih717171
Jul 25, 2016 06:22 PM
greenbackz
Jul 30, 2015 12:04 AM
ballmich
Jul 9, 2015 11:59 AM
