New turbo project sneak peak
I don't know if you guys know but I've been working on my project for awhile now. Here are some sneak peak pictures of a part of my setup. Enjoy!
I'll give ya the specs of the turbo later on.
Does that turbo even fit between the engine and the radiator fan. I'm using a T3 super 60 and I have a little room left but your turbo would eat up a T3. Good luck with everything. Can you give us more details on the project.
Retired - SoCal FI Mod
hmmmm... there is such a thing as usable power....
unless you're goning for 1000 whp or something, that size that you have there would be way over the top of a normal street car.....
a decent t3 will get you up to 500 whp with the proper precautions... i'm pretty sure you know this...
i'm guessing that it's not going in your civic huh? that's just my guess...
if it is... well... good luck...
either your swapping in a b series like some others or that going to be one hell of a street setup .. if even legal..LMAO
^^ lol i personally think its cool even though ill never do it to my car but gl with that setup. personally, my bet is that it'll spool at 5krpm....after you go through 1st and 2nd gear.
Here are some specs on it:
Cold Side:
Compressor Wheel 64mm, Inducer, 91mm Major
5 in. Inlet and 3.5 in Outlet
Hot Side
1.10 A/R Turbine Housing w/Tangential Scroll
Cold Side:
Hot Side
I think you can power 2 d17 with this one single turbo. One in front and one in the trunk.
Looks like it little to much, but hey, you can try!
I Hunt Goats, Rams, And Mustangs.
I pray to god that you have some serious internal work done to whatever moter that is giong on. if your going to hit 60psi or 3 bars of boost. and that spools up on a cheesy moter.. well ide love to see a video of that explosion! lol. Just make sure you got the camra on when you hook that bad boy up lol.
big snail
