TSI wiring help.
Old Feb 12, 2006
1990hondahf's Avatar
1990hondahf is an unknown quantity at this point
TSI wiring help.
Hi all, yeh, my first post....anyway:
I got my TSI kit installed on my 04 civic lx....al I need to to now is install the wires to the ignition. The instructions I got with my kit have NOTHING as too what wire I need to connect to....I need to know what wires under the dash I need to connect to....I'm not talking about the "E" brake wire...I got that one. it's the other ones I need help with. I'll keep searching but please if you know, post for me.
Old Feb 12, 2006
turboengnr's Avatar
DONT PANIC
take the steering column covers off. Then use a test light to find the wire that is hot with the key off, then one that is normally off, but hot with the key on.
Those will be the wires you need. I believe the constant hot wire is white, and the ignition hot wire is yellow (just trying to remember off the top of my head.
Old Feb 12, 2006
eye_see_you's Avatar
let the devil out
your right with the colors I beleive
Old Feb 12, 2006
check the turbo timer diy.
Old Feb 12, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Found this in turbo faq
http://www.7thgencivic.com/forums/sh...d.php?t=207055
Worked for me, I have no problems with it, engine started and turbo timer worked and ......I just think it 100% correct
Search for tsi and all, all, all q's are answered. No realy, I mean all questions.
trellex
Jun 30, 2015 07:13 PM
Black91civic
Jun 6, 2015 08:15 AM
davidpaustin
May 7, 2015 05:08 PM
davidpaustin
Apr 30, 2015 11:20 PM
TopFuel
Jan 25, 2002 07:03 PM
