FS: ZEX dry kit...Nitrous
Super Member
Rep Power: 0 ![GOTSPRINGROLLS is an unknown quantity at this point](https://www.civicforums.com/forums/images/reputation/reputation_pos.gif)
i got a full Zex dry kit forsale....
its a dry kit.
comes with
- fuel manage computer unit
- SS braided lines -4 and -6
- 10lb tank with 3lbs of nitrous left.
- ZEX nitrous pressure gauge
- aircraft arming switch
- mounting brackets
- all jets...from 45- 75 ( jet 32/34/35/36/38)
- vacuum lines
with a stock civic motor (d16y7- 97 whp) The engine, with a 75 shot of nitrous, made 178 hp to the wheels at 6800 rpm and 200 ft. lb. tq. to the wheels at 3000 rpm
450 obo.
ground ship only...and you pay shipping.
its a dry kit.
comes with
- mounting brackets
- vacuum lines
450 obo.
![giggle](https://www.civicforums.com/forums/images/smilies/gaygiggle.gif)
Rep Power: 0 ![canadian2k1si is on a distinguished road](https://www.civicforums.com/forums/images/reputation/reputation_pos.gif)
I have a new 2006 SI, and might be interested.
Only looking for a 50-55 shot, witth this work for me? What else would I need, do the jets have to be drilled & installed into the Intake Manifold?
Is the fuel management computer a stand alone unit, or a piggyback ECU unti?
Super Member
.the computer is a stand alone which will engage based on vaccuum..if it the nitrous is armed, and you hammer the gas, the nitrous will flow...but if you arm it; but dont hammer the gas, then it will not flow thus not risking damage.
![Tongue](https://www.civicforums.com/forums/images/smilies/face-icon-small-tongue.gif)
Originally Posted by GOTSPRINGROLLS
yep i have the jets for the 50shot. the nozzle jet is installed into ur intake piping, (plastic tube after the air filter)
.the computer is a stand alone which will engage based on vaccuum..if it the nitrous is armed, and you hammer the gas, the nitrous will flow...but if you arm it; but dont hammer the gas, then it will not flow thus not risking damage.![Tongue](https://www.civicforums.com/forums/images/smilies/face-icon-small-tongue.gif)
OK, so do you need to drill and tap holes (4) into the intake manifold for the nitrous jets? Does the computer only add nitrous not extra fuel? Is a purge line needed?
martinsmartin
08-15-2015 07:34 PM
