reverse lights as turn signal?
Old Feb 15, 2002
VTecnology's Avatar
VTecnology is an unknown quantity at this point
Is it possible to use the reverse lights as both reverse and turn signals for our civic? I'm thinking of having a bright white turn signal istead of the red one.
Old Feb 15, 2002
avenger's Avatar
avenger is an unknown quantity at this point
why?
Old Feb 15, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
You'd either have to cut a hole in the reverse light chamber to mount the blinker bulb assembly, or do some "custom" wiring. I don't recommend either option. Maybe someone else has a better option...
Old Feb 15, 2002
avenger's Avatar
run altezzias w/o a yellow bulb or a reflector for the turn signal
Old Feb 15, 2002
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
Turn signals in the back have to be either red or amber I belive... If u get rear ended you may get blamed(for them rear ending you) for not have a red or amber one and that would suck . Just my two cents.
Old Feb 15, 2002
blackbullet's Avatar
The Legend
Pseudochrist is right. They have to be either red or amber. You'll get stopped by the cops real quick if you have white turn signals.
Old Feb 15, 2002
VTecnology's Avatar
i know someone who has a hatchback. he got pulled over because he had clear corners. But now he paited it red. But the turn signal is so nice b/b it's bright as heck
Old Feb 15, 2002
VNlilMAN's Avatar
The Standard One
whether it's legal or not, it's his choice right... so just answer his question.. my suggestion would be to cut the turn signal wire n tap it into the reverse light.
Old Feb 15, 2002
GTekCiViC's Avatar
GTekCiViC is an unknown quantity at this point
Red corner turn signals are illegal...... turn signals in front corners can only be amber or yellow period.
Rear can be red or amber........ which ever
Old Feb 15, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
I'd like my brake lights to be the turn signals. Is THAT possible?
Poopies
Apr 20, 2017 11:36 PM
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
blackbullet
Dec 1, 2001 03:44 PM
mwwhonda
Nov 30, 2001 08:44 PM
