Is this right?
Old Jan 15, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Is this right?
Someone on the forums tried to tell me you can get a car running with no battery. I know you can push start a car to get it running but I thought the battery had to have some charge in it.
Old Jan 15, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Well theroedically you can, if you get the car going fast enought in gear to turn the alternator fast enought to power the coils for the plugs. So that would mean you would have to be driving fast enough already to get power. Soooo unless your being towed by anouther car... NO. You cant, you need a big enough charge to power the coils to get it jumped.
Old Jan 15, 2006
jackburton's Avatar
What about the ecu?
Old Jan 15, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
I would lean towards the practical answer of no. A manual car you may be able to get push started (like w/ a dead battery) but the alternator peaks and spikes like crazy. You'd fry everything.
Old Jan 15, 2006
XxSoVeReiGNxX's Avatar
we did that to my dad's toyota stickshift tercel after the battery died out, when he still had it many years ago. It was the first car furthest in the driveway and the jumpers were to short to reach the car behind it, so he backed out all the cars and we pushed it back and on the push foward up the driveway he got it started... i didnt know how or why, just remembered now lol
Old Jan 15, 2006
jackburton's Avatar
Was the battery still in though?
Old Jan 15, 2006
jackburton's Avatar
We need a mechanic in here LOL
Old Jan 15, 2006
v8eaterokv6's Avatar
i have a new home do u
if there is a battery in it it will accept and ups and downs in the voltage and it will be ok. i do it all the time at work with our tugs. the same thing applies to aircraft when we hook up a power cart to them
Old Jan 15, 2006
jackburton's Avatar
What about with out a battery?
Old Jan 16, 2006
it could posibly fry your ecu
Old Jan 16, 2006
R1Style's Avatar
ok... if the battery is dead you can bump start a manual transmition car by rolling it fast enough and dumping the clutch.
if there's no battery what so ever, then no you can't bump start it.
Trust me... the same theory works on motorcycles.
Old Jan 16, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I dont know about modern cars, but about 15-20 years ago my step-father used to own a LADA with carburated engine. One very cold morning (in Russia) his battery let go (dont remember what exactly happend) so he had no battery at all. We used neigbours car battery to jump start his LADA and then it ru without battery whatsoever, basicaly just off alternator...
...but as far as I know, car will idle and run with no battery, but you need battery to start engine, but then you can disconect it..
This is the car that we had in those days..
Old Jan 16, 2006
jackburton's Avatar
I know you can push start cars, the issue is whether or not the battery needs to be installed.
If you disconnect battery while engine is running you will prob fry many things. So you could not start a car with out the battery installed. Also, there would have to be somewhat of a charge in the battery, or otherwise you would have to be towed at like 20mph. So the battery cannot be completely dead.
I think I got it now.
Old Jan 16, 2006
Originally Posted by jackburton
I know you push start cars, the issue is whether or not the battery needs to be installed.
If disconnect battery while engine is running you will prob fry many things. So I assumed that you could not start a car with out the battery installed.
Oh, my bad..missed on topic. For me not getting it right -
But I'll say "yes" to battery, if you need to jump start...
Old Jan 16, 2006
jackburton's Avatar
Oh yeah and this for a civic.
I could see it might work for older cars, maybe...
Old Jan 16, 2006
This car is carburated and it didnt have any computer or sensors to contol anything - there is nothing to contol..lol..
If I remember right, it had coil type of ignition with mechanical distributor...wel like most cars that were designed in 70s.
Old Jan 16, 2006
dj02's Avatar
whats the point of this thread and why is it in the tech diy section? is there a problem you need fixed that you have to run your car with out the battery or are you just wondering if it would work?
