trouble taking off steering knuckle?
Old Jan 15, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
well im having some trouble removing the bolt connecting the lower control arm to the steering knuckle [i think thats what its called] the whole assembly that has the rotor,hub and caliper attatched on it. yea my buddy told my i just hammer the sides of the control arm until it breaks lose but i did it for like an hour and it never came out of its hole. any suggestion are appreciated. thanks
Old Jan 15, 2006
tfnaaf's Avatar
BLDNPSI Mod
make sure the strut is still attached to the knuckle, use a pry bar on the lower control armto pry down on it. Then with a large hammer strike the side of the control arm where the ball joint stud goes thru. Im assuming that you have removed the nut from the ball joint It shouldnt take all that much force to break the tapper fit. If your unsure of your aim with the hammer leave the nut on the ball joint a coulpe threads to protect it from the hammer
Old Jan 15, 2006
thank you d man i searched the whole thing and all i needed was this thanks
Old Jan 15, 2006
wow ive tried EVERYTHING that i could possibly think off and that bitch still isnt coming off. i have searched and i tried everything and the bolt is still not coming off... HELP
Old Jan 15, 2006
djmota's Avatar
all you need is the right tool. a tie rod end tool rent one form a local auto parts store.
Old Jan 16, 2006
djmota's Avatar
link to one style
http://www.mytoolstore.com/toolaid/suspn02.html
Old Jan 16, 2006
wow thanks i think i will make a trip to autozone today thanks man i hope this works!
Old Jan 16, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Also, I know another way, at least that what i've used in my 03 Acura EL
Screw nut from the rod 5 levels of theread or so, as long as you wont see the thread, the nut will protect all thread from damage. Then hummer it out from the bottom and it should come out. It took me no time to finish with it.
Hopefuly I comprehed the process well...
Old Jan 17, 2006
sweet. i got it off. i just ended up buying a bigger hammer and hitting it with 2 hands.. thanks for all your help guys i appreciate it
Old Jan 17, 2006
All right!
Where you using one of those "Playschool" type of hammer initialy??
Old Jan 18, 2006
lol just like a hammer that you hammer nails with. dont know why it wasnt coming off >_<
Old Jan 18, 2006
Its good you took care of it with little blood.
Are dropping your civic?
If you are, then make sure you will allign front struts when putting them together. Otherwise your front suspention will make funny noises
Old Jan 19, 2006
dariusld's Avatar
dariusld is an unknown quantity at this point
If I didn't know what you were talking about, I would have no idea what your talking about. Especially since you didn't say it correctly. Maybe because your canadian
Old Jan 19, 2006
lol naw its cuz i broke off my wheel studs. but now therse a squeeky noise comin from the side i replaced the studs. heard a lot about this problem. im gonna search
Old Jan 20, 2006
This is how I've learned about index marks (!) on the front struts, I did not say right earlier..lol...Anyone can forget things
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
GolNat
Suspension DIY
May 12, 2022 06:49 AM
mattdoc
Mar 14, 2017 12:10 PM
bsmiley
Apr 27, 2015 01:27 PM
JDQuikCivic
Nov 22, 2001 01:26 PM
