Emanage Pressure Sensor input to Zeitronix Wideband
Old Jan 12, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Sorry if this is in the wrong section but figured I'd get the best response being here.
I have a Zeitronix Wideband unit which measures my A/F,EGT,RPM,TPS. It also has an input for another input called "User". This can read voltage from any other unit that you want. It can read up to 5 volts. What i'm wondering is if I can wire up my Greddy Pressure sensor to that User input? Will it give me the voltage reading from the pressure sensor to the wideband display?
This would help me tune easier instead of having both the wideband and emanage program running at the same time. this way I would only have to look at the wideband then go back and do adjustments. Discuss..
Old Jan 12, 2006
tfnaaf's Avatar
BLDNPSI Mod
it should be the white wire as i recall
Old Jan 12, 2006
tfnaaf's Avatar
BLDNPSI Mod
i have mine hooked up to my plx-m500 but still cant get the RPM to work
Old Jan 12, 2006
XSRCivic's Avatar
you have the pressure sensor input hooked up to the plx? the plx isnt reading rpm? check see if your emanage is, then tap off of that wire.
Old Jan 12, 2006
tfnaaf's Avatar
BLDNPSI Mod
yes, ive tried a couple different settings, maybe im just being mental. im going to try to redo the connections again just to make sure they are good. My TPS, boost, and AFR all work flawlessly
lilrob1213
37
Jun 29, 2015 06:45 PM
aontkos
Jun 21, 2015 08:21 PM
BootyDo
May 8, 2015 05:36 PM
dosmastr
May 5, 2015 12:19 PM
darelldd
General 7th Gen
18
Feb 24, 2002 06:31 PM
