water temp gauge install?
Old Dec 8, 2005
Can you just tap the wires for the stock sender, or will that not work correctly? What about putting a T in the coolant bypass hoses for the throttle body?
Old Dec 8, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Its best to put it in the return hose. Lots of places sell sensor housings.
You can't tap the stock sensor, its just an idiot switch.
Old Dec 8, 2005
the return hose meaning the upper radiator hose?
Old Dec 8, 2005
Jap-Euro Fusion
yeah, the upper hose.
Old Dec 8, 2005
tfnaaf's Avatar
BLDNPSI Mod
I made my own
Used a Sprinkler system coupler and got creative
Old Dec 8, 2005
nice. i still don't know why you can't just tap the tb coolant hoses? would be so much easier and won't that give an accurate reading?
also what about auto trans temp? can I tap the tranny cooler hose? and if so which one incoming or outgoing?
Old Dec 8, 2005
Jap-Euro Fusion
The measurement that matters is whats leaving the engine and going back to the radiator. Thats the HOTTEST that the coolant is going to be, and thats the place you should measure it for that very reason. If its a good value at its hottest, then you're good to go elsewhere. Tapping the TB is like sticking the gas tank level in the filler neck. Its just not going to read right. And I dunno if you have the guage already, but the sensor probe is about 1/2-3/4" long. You need a fairly big tube to stick it into.
Xuhme
21
Aug 7, 2023 03:40 PM
brian257
Jun 4, 2015 08:17 PM
zaboomafoozarg
May 30, 2015 09:21 AM
AlphaInfinity
Nov 21, 2001 03:15 PM
meels808
Nov 9, 2001 03:08 PM
