Sponsored by:
Sponsored by: CARiD
ATTN Toasty
Old Feb 10, 2002
mohawkboom's Avatar
ATTN Toasty
Where to find Aftermarket Horns????
Old Feb 10, 2002
speedyJB's Avatar
speedyJB is an unknown quantity at this point
hve seen them at autozone... check pepboys... or advance auto parts
Old Feb 11, 2002
toastyghosty's Avatar
toastyghosty is an unknown quantity at this point
picked mine up at a local store called canadian tire....
try at pepboys if you're stateside...i believe another member on here picked up the same horns i have from em.
Old Feb 11, 2002
ASIANPRIDE's Avatar
GODLIKE
ASIANPRIDE is an unknown quantity at this point
How crazy do they sound....Like is it anything like a SemiTruck or anything...or is it just a dif sound....cuz our OEM ones blow....
Old Feb 11, 2002
tsunamisplash's Avatar
tsunamisplash is an unknown quantity at this point
seeing as toastyghosty was "nice" enough to test them as i was helping to install them.. i was "lucky" enough to be one of the first to hear it. i don't think anyone else got as close as i did to it.. haha..
it's pretty darn loud for a disc horn. it's not an air horn tho, so it doesn't quite sound like a semi.
Old Feb 11, 2002
Amphiprion's Avatar
Amphiprion is an unknown quantity at this point
I relpaced my horn as well. I bought 2 FIAMM horns from autozone (about 10 bucks each), and put one on each side. Here's a tip.....1) if you have oem fogs, the horn will not fit in the original mounting position so you just have to mount it somewhere else..........2) remember to wire the horns (that is, if you decide to use 2) in parallel, daisy chaining (wiring in series) will not work. Much luck to ya.
Old Feb 11, 2002
Eman's Avatar
Eman is an unknown quantity at this point
I'm installing 2 hella supertones this weekend. i know I have to take the bumper off, but what does it mean when you say "daisy chaining" or series wiring. What i'll be doing is connect 2 positive wires from both horns together with the wire from the car and the negative terminal to the horn bracet as ground. Will this work? If not, please let me know what will.
Thanks
dezod
Mid Atlantic
Aug 19, 2007 07:57 PM
RHCP0801
Oct 11, 2006 10:38 PM
DMikeX
South Cali
Jun 27, 2005 01:51 PM
RIC3BOY
Aug 18, 2003 10:16 AM
dezod
Mid Atlantic
Jul 15, 2002 11:41 PM
