ex to dx engine swap
Old Nov 16, 2005
mclean987's Avatar
mclean987 is an unknown quantity at this point
hi i have a 2002 ex and my block is dead so my friend has a very low mileage dx engine with only 9000 miles on it selling real cheap, so i wanna use the block with my old vtec head so i just wanna know what i need to do to dx block to make it like a ex, is there anything i need to take off my old ex block and put on dx block ? do i have to remove or install some oil squirter or something? also i might just keep dx engine in there for a while before i swap the head because i just need to get the car driving now, any questions comments concers would be appreciated
Old Nov 17, 2005
mclean987's Avatar
some please respond any little info would be great, anyone know if the ex d17a2 and dx block d17a1 is exactly the same or are they different ?
Old Nov 17, 2005
dj02's Avatar
http://www.7thgencivic.com/forums/sh...d.php?t=169411
this should help you yes it can be done.
Old Nov 17, 2005
Rufus's Avatar
I could do it all in 12 hours I bet. Prob. less
Old Nov 17, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
well since you have all the stuff ready from the ex motor, you could pull it off.
Old Nov 17, 2005
mclean987's Avatar
thanks for responses i think im gonna put dx engine in first just to get car driving and then swap the head later, or do you guys think i should remove dx head now and put ex head on before i put engine in car?
Old Nov 17, 2005
MajinB's Avatar
if you can pop the head off. i mean its a day of work for a lot more natural feel. there is deffinetley a difference in feel between an ex and dx
Old Nov 17, 2005
mclean987's Avatar
yeh true but im definately gonna do it but i cant spend couple days on it so might put dx engine first and then swap head, i cant have a ex car with a dx engine, im gonna use thinner head gasket and shave the head aswell
Old Nov 17, 2005
mclean987's Avatar
anyone know if i have to change timing belt to ex from dx when doing the head swap?
Old Nov 23, 2005
mclean987's Avatar
ok i installed the full dx engine in my 02 ex civic but the engine wont rev over 4000 i think its the vtec ecu what should i do ? thinkin of getting a dx/lx ecu temporarily
Old Nov 24, 2005
Rufus's Avatar
I would agree with you. 4000K is usually limp mode. When the conditions aren't right for vtec to engage the computer won't let the engine go beyond 4K RPMS
Old Nov 24, 2005
mclean987's Avatar
ok is dx /lx ecu the same and dont you have to change something with carkey when you change computer something to do with immobiliser
Old Nov 24, 2005
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
the full dx engine will not rev past 4000 because it doenst see the vtec cause your still running the ex ecu.. if you use the dx/lx ecu then you gonna need to tow your car down to the dealer to reflash your key... my suggestion is to swap the ex head back on and connect the vtec connections back uip.. that should fix your rev problem
Old Nov 28, 2005
mclean987's Avatar
yeh your right but i dont have any time now or can i afford downtime to install head and im gonna shave head maybe pnp and wanna put a cam and valvetrain in when i put head back on so i just wanna run dx temporarily, so i cant drive to dealer then change ecu there and let them teflash key? how much do they charge and will they do it since the car is a ex and engine and ecu ar dx ?
Old Nov 28, 2005
ajhdragon's Avatar
7thgens official a$$hole
the dealer will change the key. i think it is $30 to get it flashed.
Old Nov 28, 2005
it varies from state to state and dealer to dealer.. do some calling around
RicoSuave
May 20, 2015 01:57 AM
cloudguy
Apr 28, 2015 05:02 AM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
