Problems after T-belt/cam gear change?
Old Oct 15, 2005
Well I wouldn't call them problems, but its kinda interesting that these things happened after replacing t-belt, water pump, and pulley, and putting an aem cam gear advanced 2 degrees. First the car warms up and cools down very fast. Alot faster than before. And I'm talking less than 5 minutes from a cold start the temp needle is up where it should be. Second, my AC is ice cold. Before it was cold enough but now its like putting your hand in the freezer. I'm not complaining, just wondering what happened.
Old Oct 15, 2005
MIVtec's Avatar
MIVtec is an unknown quantity at this point
How many miles did you have on your car, when you made all of these changes??
Old Oct 15, 2005
42k miles
Old Oct 15, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Errrm.... if you find out what caused that, let ME know so I can duplicate it, would ya??
Old Oct 15, 2005
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
just wondering why you did the water pump under 50K? i put an AEM cam gear on when i did my head gasket but i had clearence issuses, so i took it off. but the A/C and watnot are totally not related..pretty cool tho
Old Oct 15, 2005
ya i did add the special long life blue honda coolant but thats not really tied to anything. Oh maybe my ac belt was loose? For the cam gear, you have to remove all the plastic dust covers or it will rub and dig grooves in it. I learned the hard way. But yea water pump might as well since they were pulling everything off anyway. Now I don't have to worry for a while. Do you think i should have done the thermostat too? I guess that can be done anytime tho
Old Oct 15, 2005
streetglower's Avatar
I was thinking the same thing. I want an ice cold AC.
As for the thermostat, it cant easily be done at any time. Its not an expensive part, so might as well go ahead and do it anyway.
Old Oct 15, 2005
well i already had everything done last week. thermo never came up. I thought its just that piece near the battery thats on the engine? Not really near the t-belt area.
Old Oct 15, 2005
the thermostat is located at the inlet to the lower radiator hose. you need to remove the hose and the thermostat cover to access it.
sysblack
May 13, 2015 08:55 PM
cruisers10
May 12, 2015 10:46 PM
Ashley Farr
May 7, 2015 05:01 PM
dooner24
Apr 14, 2015 07:51 PM
02Si
Dec 14, 2001 10:26 AM
