FS - JIC Magic FLTA2s - Buy Them!
Old Oct 13, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
They were in my car for a year. I re-rated the springs for some more rearward bias. They come with 503 lb-in F/ 559 lb-in R, Front springs were replaced with Hypercoil racing springs ($129/pair) they now have 400 lb-in front/ 559 lb-in rear. Lower front brackets have some coating corrosion, its, its tarnish on the gold plating from a combination of brake dust, grease and water trapped between the knuckle and the bracket, some of the welds have some corrosion on them, but this is pretty normal with any non-stainless steel welding job, makes no big deal other than its looks blackish, you can't see them anyways. Some minor rust dots on the ram sleeve on the front struts. The shock guts are underneath this and it's just the protective sleeve, once again, no operational problems caused, think of it like a dirty dust boot. Black stuff in the threads is graphite from the thread grease I've been using on them, it has no ill effects, infact it helps the threads stay corrosion free. Setup is currently dissassembled for a thorough cleaning, it also answers the threads stuck question, no, they're not. New spring rates are more applicable to an EM/ES application with less weight on the front end. The rear bias will cause oversteer with stupid manuvers, so be aware of that. They have been raced on, but thats what they're intended to do and they do it very well.
Dampers are 15 way adjustable
Inverted monotube struts
Adjustable length damper bodies (3rd lock nut)
Preloadable springs
Camber plates (will go to about -2.5 deg)
Pillowball upper mounts on all 4 corners
Spanner wrenches included
Aluminum Spring seats
And the rest of the list (read the JIC website)... I'm assuming anyone who's buying them knows what they're buying.
I pulled them to make way for my tinker project suspension (Konis/GCs/Camber plates and all the custom crap). I didn't have any problems with these other than I wanted something that was a little more customizable on the fly (changing springs on these requires taking them out of the car).
They ride very firm, no bitching about firm rides on racing suspensions. The spring rates can be lowered by swapping springs. They take standard 2.5" racing coils, 8" in the front, 6" in the back. Choose your rates and brands.
It fits 2001-2005. Yes All of them. The kit is for the EP3R.... 16mm crash bolts. I used them with 14mm knuckles. I'm sure you all want to know how... because I did it without bushings to cut the diameter down (which you can do if you choose). All you have to do is install as usual, before you torque the bolts down, push up and in hard on the knuckle, and torque them to heck. It worked, they never moved. The angle at which the knuckle fits in prevents if from coming out. It actually buys you about 1/2 a degree of negative camber right off the bat.
The price on these works like this.
I'm in DC. If I can get to you in 60 minutes or less based on mapquest's estimates, I'll deliver them to you.
60
More than 60, you come to the 60 mile line.
$900, which is way down from what it started at 6 months ago. I really don't want to go any lower, this is a rediculous deal on a $2000 suspension.
If you want me to ship them..... plan on paying for it. Its probably going to be more than 50 bucks IF I can even find a box sturdy enough to ship them.
I'll also entertain trades for 15 or 16x7.5 (NOT 7) 4x100 wheels of similar value (read: they better be forged)
File Type: jpg
Old Oct 14, 2005
Jap-Euro Fusion
Bump bumpety bump
Old Oct 14, 2005
Jap-Euro Fusion
"dibs" have been called.
The line starts here.
Old Oct 27, 2005
Jap-Euro Fusion
Deal fell through. Back up for sale again.... If someone buys them before this weekend is over, take $50 off. or $900 shipped
Old Oct 30, 2005
Jap-Euro Fusion
Bump
Old Nov 1, 2005
Jap-Euro Fusion
Bump... come on someone... I need money for big fat *** rims.
Old Nov 2, 2005
specks's Avatar
specks is an unknown quantity at this point
i've been reading your suspension post for years now and I know you're a wiz with suspension.....so why give up the prestigious name of jic for your own custom setup of koni's and cg's? I know that koni's are great too, but do you personally think that they'll out perform the jics in auto-x. I've personally been wanting to go with koni's, linear spring rated SWIFT springs, and Tein camber plates. I want to hit 120 degree turns in the 80's and pull out smooth and also sharp cornering. what do you suggest I use in my suspension set-up? how much stiffer that stock is 400lbs rated springs in the front uhhmm percentage wise and 559lbs for the rears over stock?
Old Nov 2, 2005
spoonEM's Avatar
omgwtfbbq mod.
damnit...i wish my rotas were forged..
bump for a SIIICK suspension set-up
Old Nov 2, 2005
Jap-Euro Fusion
I like to adjust things. I also like to tinker, so building my own custom setup was a project more than anything. I do think the koni's are valved better for autocross, I think the JICs were much better suited for the race track, I gave up one for the other. If you find a way to hit a 120 degree turn at 80 MPH, you let me know, cuz I don't know of any car that can do that unless the radius of the corner is so huge that you're not really turning. 400/559 is probably about 2-3 times stiffer than stock. Its a guess, since no one knows the stock rates (progressive springs change).
Old Nov 2, 2005
Al Gore FTW's Avatar
jdmtytedoridori
bump for boiler, he helped me out with a bunch of q's i had back before i started messin with the suspension on my car.
Old Nov 3, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Ok a couple of quiestion a friend is interested
How do you service them if one of the dampers gets fugged up?
Whats shipping on thse to Laredo, TX 78040?
Do you offer payment plans?
Old Nov 3, 2005
Jap-Euro Fusion
They have to go back to JIC in california who probably sends them to JIC Japan
Best guess on fedex.com is about $40
ummm. No. All the money up front, I'm not a bank.
Old Nov 6, 2005
Jap-Euro Fusion
Old Nov 11, 2005
Jap-Euro Fusion
Bump bump bump.
Old Nov 11, 2005
Jap-Euro Fusion
$900 shipped. Come on people, this is a good deal on some good ****. I just bought new wheels, I need room. Someone take em.
Old Nov 11, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
Bump for boilermaker!! Did you try to sell them on club RSX or ephatch.com?
Old Nov 11, 2005
Jap-Euro Fusion
I'm not a good enough postwhore to rack up the 200 posts to sell things.
Old Nov 20, 2005
Jap-Euro Fusion
up again
Old Nov 22, 2005
Jap-Euro Fusion
OK... seriously, someone's gotta buy these. If you've got a FAIR offer, make it. If you're embarrased to make the offer, then don't make it
Old Nov 26, 2005
Jap-Euro Fusion
Bump... if you didnt spend money on black friday... give it to me. I'll send you these as a gift.
Old Nov 26, 2005
EM2typeflex's Avatar
EM2typeflex is an unknown quantity at this point
^^sup boilermaker, someone was looking for these awhile back in the wanted section. thought I'd give you the heads up buddy.
free bump for some nice coilovers
Old Nov 28, 2005
Jap-Euro Fusion
Bump... seriously. Come on. I need this money for big surprise #3
Old Nov 29, 2005
ImportRacer2123's Avatar
K20 Member
BUMP FOR YOU!!! Great Coilovers I would have Bought them If i saw them the time I saw my TEIN Basics...
Old Nov 29, 2005
Jap-Euro Fusion
Up again
Old Dec 1, 2005
Jap-Euro Fusion
bumpedy bumpedy bump.
Come on... its the holidays. I'm generously giving you the gift of handling.... someone give me money. Because tis the time of the year for giving.
Old Dec 4, 2005
Jap-Euro Fusion
Bump...... someone? I'm taking fair offers and no one's even offered me something.
Old Dec 4, 2005
vietstylez's Avatar
i will offer you my xbox 360, and accessories
Old Dec 5, 2005
Jap-Euro Fusion
nah, I need money, but I bet someone would buy the Xbox and then you could send money
Old Dec 5, 2005
vietstylez's Avatar
haha..i would if i had a clue how to use these things to their full potential
Old Dec 5, 2005
kornsined's Avatar
WOW this is an insane deal and no one's bitting. I don't autocross so if I were to buy these it'd be a waste IMO. I'd more then likely be bitching about too stiff of a ride as well. Good deal nonetheless.
