Timing nitrous
Old Oct 5, 2005
Turbociv's Avatar
Turbociv has a little shameless behaviour in the past
Timing nitrous
I got 7 pounds of boost and i was going to put a 25 hot on my motor too. SHould i retard my timing any?
Old Oct 5, 2005
tfnaaf's Avatar
BLDNPSI Mod
Once you go to turbo hell the next step is turbo heaven.............
160 WHP @ 4PSI
im confused, but none the less you most likely wont need to cause it has a cooling effect on the intake charge
Old Oct 7, 2005
ncirom2003's Avatar
good topic, ive always wondered about NO2 in FI apps.
so if im boosting at say 8 lbs...... would it be safe to shoot a 50 shot dry into the car? i was thinking of doing it at WOT but maybe at the low rpm while the turbos still spooling and the power sucks. do you guys think this is safe either way on stock engine? let me knwo cus i was always under the impression that no2 can cause damage if you run it on a boosted engine because ther is so much pressure already in there.
Old Oct 8, 2005
iamboo's Avatar
Retired - SoCal FI Mod
it won't be a problem as long as there is enough fuel... there were a couple members on the boards long time ago that ran 75 shot with turbo and it was running fine... this would only be used off the line to counteract turbo lag...
if you wanted to run nitrous with turbo running 8lbs in the middle of a 1/4 mile pass, the bottom end would definately need to be built...
Old Oct 8, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
...and transmission with axels...
Old Oct 8, 2005
iamboo's Avatar
well yea.... you're eventually gonna have to upgrade those and other things as well... but i'm just saying engine wise.....
and to answer your question... i personally wouldn't touch the cam timing at all if that's what you're refering to... i've seen a lot of weird things happen to cars when untrained tuners try and mess with it... a good example is when my friend with a 97' twin turbo supra took his car to a shop that "adjusted" his cam gears for him and ended up detuning the car to a 185rwhp.... he thought something was wrong when he raced a stock b16a crx and lost by 5 cars...
Old Oct 8, 2005
Doent stock ECU adjust timing automaticaly???
Old Oct 8, 2005
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
fuel timing yes. but not valvetrain timing. basically you can achieve the same thing but from what i understand, with a boosted engine you don't want to adjust your valve train timing, just your fuel timing.
Old Oct 8, 2005
tfnaaf's Avatar
BLDNPSI Mod
The stock ecu will adjust ignition timing im unaware of any fuel TIMING that it adjust. im pretty sure it sprays each injector at the same time thru the crankshafts rotation and doesn't variate its timing per say but only its duty cycle. Please corect me if im wrong, its been better part of 15 years since ive actually been to any formal fuel injection training, and im getting old!
crowtoo
May 11, 2015 06:50 PM
MamaBear2015
26
Apr 16, 2015 11:08 PM
vtecdoc
Dec 19, 2001 09:15 PM
supercivic01
South
Nov 30, 2001 11:27 AM
Cilvic
Nov 15, 2001 04:54 PM
