DC racing headers
Old Sep 21, 2005
vietzboi87's Avatar
vietzboi87 is an unknown quantity at this point
DC racing headers
I installed my dc racing header with downpipe couple days ago and i accidently burn the 02 wires by leaving it too close to the headers . So after i redid the wires my alternator doesnt seem to work and my mph and rpm doesnt work at all. I checked the fuse and the wires i redid but doesnt seem like any of it is wrong. I need helpp any suggestion people!
Old Sep 21, 2005
diskreet's Avatar
well disconnect the battery for a few mins. let it all reset. if that still doesnt work get the car scanned to see if it is throwing a code!
also make sure you didnt burn any other wires!
Old Sep 21, 2005
PiNoYxRaCeRxRH's Avatar
PiNoYxRaCeRxRH is an unknown quantity at this point
that sucks really bad
Old Sep 21, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
put the old header back on and take it to the dealership. or go find a personal mechanic. good luck
Old Sep 21, 2005
vietzboi87's Avatar
yeh i tried resetting the ecu still nothing. Last thing im going do is get a new alternator but im just asking to see if i can get any help before i bring it to the dealer.
Old Sep 21, 2005
vietzboi87's Avatar
I only burned the wires that connects to the headers 02 sensor so that shouldnt mess up the mph or rpm right?
Old Sep 22, 2005
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
just get a new alternator and another o2 sensor.
Old Sep 22, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
first off, get your o2 sensors away from the header ... the wires might be grounding out your system. make sure they are NOT touching the header
second, look under your steering wheel, near your pedals ... there are a shitload of fuses ... there is one fuse in particular (10 amp) that probably blew if your o2 sensor wires grounded out on your header. replace it.
Old Sep 23, 2005
streetglower's Avatar
like some other people said, if you burnt the wires close to the o2 sensor, just replace the sensor. It sounds as if you did rewire everything wrong and now signals are going places they shouldnt and causing other components to not work properly. That is the only thing I can think of.
Old Sep 23, 2005
Jrfish007's Avatar
test the alternator before replacing it... Autozone does it for free I think.
Old Sep 25, 2005
vietzboi87's Avatar
ite thanks guy i got it to start back now. The only thing on is the engine check light, I guess thats normal for having the racing headers on.
UltraHDGames
Jun 8, 2016 05:16 PM
anubis62
Sep 27, 2015 12:56 AM
